This section
Sponsored By
04-20-2008, 07:02 PM
Administrator
Jeep :
Year :
Lift :
Tires :
Real Name: Terry Mason
Subwoofer inside of a Jeep Wrangler rear seat
After a year of listening to the stock speakers in my 2005 Jeep Wrangler I was ready for an upgrade. At one point I had installed a sub box behind...
Looking for Jeep Parts? Check with the Jeepz.com vendors - they help us keep the lights on!
TerryMason's Arcade Awards
Re: Subwoofer inside of a Jeep Wrangler rear seat
my friend has a kicker 12" sub in his civic and knows a reasonable amount about car audio and told me that the slim speakers are more for rock and dont hit the low notes he said if you play a rap song with low notes it wont produce good quality do you think this is true?
That's some really great work Terry.
Does anyone know if this idea is feasible for a 2-door JK?
Quote:
I've never seen one built, but that's just because I've never been in a JK. I don't see why it wouldn't work.
Great work building it, looks and sounds great. I'm planning to try and replicate it, my jeep got broken into, so this a great stealth sub. Have you thought about mounting the amp inside the box? I was thinking of doing this, I'm not sure if it will have any impact on the sound or not..
Can you tell me the name of the song that's playing on your video?
That's some cool tunes..........
Thanks,
Rod
I originally planned on mounting the amp inside the box, as these subs don't require much airspace - you could do half sub, and half amp. I ended up not doing that because my old amp is huge, and there's no way it would have fit.
The song is A little bit more by Jamie Lydell
Amazon.com: Multiply: Jamie Lidell: Music
Gotcha. Your sub is a 10" right? What kind of AMP did you have running in there? Do you know the wattage and how many channels? Just curious. Sounded really nice, I could see the sub really handling it well.
Thanks for the info.
Where did you mount your amp and crossover?
Thanks
Quote:
Thanks
I don't have a crossover (my head unit has subwoofer controls / crossover built in). I never ended up mounting my amp - it's sitting on the floor behind my seat. I always meant to do something with it, but never got around to it.
how much was all of this, seems fairly cheap?
Question to the OP, why'd you opt to put one sub? Is there a disadvantage to mounting two 10" subs in such a tight spot?
I'm considering doing this mod with two Pioneer 10" shallow subs you mentioned earlier. I was gonna power it with something like this:
http ://w ww. crutchfield.com/p_098CO5001/Orion-Cobalt-CO500-1.html
Would you buy that, or is there another brand I should look for?
From what I read, if I wire the subs parallel, then at 4 ohms a piece @ 250 watts RMS, then a mono amp putting out 250 watts at 2 ohms should work... Am I on the right track?
just did my install of this, I did a little bit change to the box I have an 02 tj, made the box 24 x 13 inches, and installed a 12 inch kenwood sub with a 600 watt amp, sounds great thanks for the info
Quote:
Very cool - post some photos of the install when you get a chance
It was fairly easy to put together, sorry it took so long for the photos but all in all it took me about 6 hours to do, that is with runs to the store for supplies and buying the amp and the woofer
for using the 12 " sub, what was the depth of the box? (what was the measurement of the side pieces?) 24 x ...
I bought I slim sub woofer, so the depth was 3 and 1/4 inches, width of 13
Hey looks great, you said that you have a shallow mount kenwood woofer, 3 1/4 deep. I have a rockford fosgate 12" w/ top mounting depth of 3 5/8" do you think it is possible to add 1" to the depth of the box. I understand this will make it not possible to zip the bottom carpet back on and will probably have to raise the seat some, but besides that do you think it would work??? Thank you, appreciate any help on this....Kenny
Wow - great project! You should start a business!
Re: After photos
Quote:
Originally Posted by TerryMason
After photos
looks great,good idea.
By
inDmud
on
11-09-2009, 02:47 PM
Nice work fellas!! I've been fumbling around trying to figure out where to mount a sub as well as the amp. This DYI'er along with
community.webshots.com/album/63423573sSraTy?start=0
sorry, but I don't have enough posts to add links... I'm a newbie.
lead me to this conclusion. I may actually mount an 8" sub in the armrest and mount the amp under the rear seat as described in this thread. Being as though the amp won't fit in the armrest I think this may be a nice option. Has anyone else seen the armrest sub enclosure from Doug? Everything would be completely out of sight.
| Article Tools |
| Display Modes |
Linear Mode
HTML code is On
