Make your own LED strip halo lights!
Cheapest way to get LED lights is to go to amazon and buy the appropriate length for your headlights then simply stick the led strip to the outside of the headlight, and wire them to your battery and to a switch. I advise you to get someone that knows how to wire correctly. If any type of wiring is done incorrectly, it can catch fire, however if it's done correctly you will have no problems.
They look pretty good! Do you have a link to the led strip that you used? Also, did you just stick them to the glass of the bulb, or the housing around the light?
I'd worry that the bulb would get too hot and would melt something.
