Go Back   Jeepz.com > Technical Forums > All other Jeep models
This section Sponsored By
Old 07-22-2005, 08:33 AM
Send a message via AIM to SenorCole86
RE: Re: RE: Modifications on gear for HEI
What rear end would an '87 pickup have, and would it fit on my '80 CJ with narrow track axles? I'll probably only be interested if it's a D44. Any help at all would be greatly appreciated, thanks y'all!
1980 CJ-7 Renegade
Motorcraft 2150 Carb / GM HEI Ignition / 4.0 HO Head / Clifford Cam+Valve Train / Painless Wiring Harness / Bedlined Interior / 31" TRXUS M/T's / 1.25" Spidertrax Spacers/ and some indeterminate amount of suspension lift
I'm an auto mechanic who works on a doesn't need to know basis.
View Public Profile Send a private message to %1$s Show SenorCole86 gallery
Old 07-23-2005, 02:19 PM
Bounty__Hunter's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
6"
36"
RE: Doetsch Tech shocks
'87 Comanche (MJ) or J10 or what?
'87 MJ will have the D35 or D44, and the J10 is likely a HDAMC20 or D44 (much wider than the MJ and your CJ).
Old 07-23-2005, 05:07 PM
Well, it was a tiny little pickup if that helps. I don't remember what kind it was, I don't think it was a J-series though, because the J-series were all pretty large, weren't they? I guess it was a Comanche then. But either way, the axle will be too wide?
1980 CJ-7 Renegade
  #4 (permalink)
Old 07-23-2005, 11:14 PM
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
6"
36"
Sounds like a Comanche, so it should be the D35 or D44. Either would be good width for your jeep, but the D35 would be a lighter axle that what you have now. It will be a different lug pattern than your current axles.
The J series were full-size trucks.
  #5 (permalink)
Old 07-24-2005, 02:57 PM
RE: Throttle body help
Alright, good deal, thanks. I'm gonna go see if its a D44 or a D35, then maybe pick it up, think there's any chance it has 3.07 gears?
1980 CJ-7 Renegade
  #6 (permalink)
Old 07-26-2005, 09:06 PM
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
6"
36"
RE: More advice for a noob
Possible, but 3.55 were more common. May be 3.07 if it had a 5spd, but who knows with Jeep.
  #7 (permalink)
Old 07-26-2005, 11:36 PM
Real Name: Chris
An XJ or MJ rear axle is going to be about 3" wider PER SIDE than your narrow track front.
View Public Profile Send a private message to %1$s Show Junkpile gallery Junkpile's Arcade Awards Asteroids
 Subscribe to our RSS feed
