Go Back   Jeepz.com > Technical Forums > All other Jeep models
This section Sponsored By
Old 07-13-2008, 11:07 AM
Real Name: Mike
Question 79 Jeep J10 tech question
My truck started running pretty rough and stumbling so i took a peek under the hood, found vacuum leaks. I replaced 90% of the vacuum lines, the fuel lines, fuel filter, air filter, accelerator pump (which was worn out) and tested the vacuum ported switch with a shot of gum cutter. There are currently no leaks in the vacuum system yet it still stumbles. I still have the original motorcraft 2 barrel and it is a bone stock rebuild with factory specs.
any advice for what else to check?
MIKE.
View Public Profile Send a private message to %1$s Show mikecetj gallery
Old 10-12-2008, 09:29 AM
Real Name: Steven a.k.a. Vee Dubb
Send a message via AIM to VeeDubb Send a message via Yahoo to VeeDubb
Re: 79 Jeep J10 tech question
Does it have a miss? Has it been running like this since the rebuild, or has it run fine after the rebuild?
View Public Profile Send a private message to %1$s Show VeeDubb gallery
Old 10-26-2008, 09:20 PM
Northman111's Avatar
Real Name: deerslayer
Which engine do you have?? Six or eight. Either way sounds like you sucked up some gunk in the carb. ( Fuel side )
View Public Profile Send a private message to %1$s Show Northman111 gallery
  #4 (permalink)
Old 11-01-2008, 04:06 PM
Member
International Full Size Jeep Association - Powered by vBulletin
Check out this site. We are Full Size Jeeps only and you can find all you need there. I have the same user name over there and hope to see you....
You might check the shaft on the butterflies to see if its worn out.
1-\'51 Willys truck
1-\'51 Willys Wagon
1- \'74 CJ5,
1-\'75 J20 Wrecker
2-\'77 J10 p/u
2-\'79 Cherokees
1-\'85 Grand Wagoneer
1-\'88 Grand Wagoneer
I DO IT FULL SIZED....
View Public Profile Send a private message to %1$s Show jaber gallery
  #5 (permalink)
Old 11-26-2008, 02:25 PM
Member
Real Name: john.r.bradbury
grab the carb and twist and wiggle it to see if it is loose from the manifold. also, one time i had the pcv hose burned through on the bottom side where i couldn't see or feel or hear it and i only found it when i tore the intake off. good luck, john
View Public Profile Show ka041a gallery
  #6 (permalink)
Old 01-27-2009, 09:09 AM
carnuck's Avatar
Jeep :
Year :
Lift :
Tires :
Comanche
1988
6"
33/9.50/15s
Timing too far retarded or fuel too old will cause this (bad vacuum advance too)
View Public Profile Send a private message to %1$s Show carnuck gallery carnuck
Tech Forum- Jeep Receiver LadyJeepFreak CJ YJ TJ and JK 3 04-24-2008 08:07 PM
Stroudsburg HI-TECH JEEP White General Chat 8 03-22-2004 07:15 AM
NOn Jeep Tech Question? Tug-n-pull CJ YJ TJ and JK 12 07-20-2003 07:00 PM
tech question sent to me for a CJ PASmokeater CJ YJ TJ and JK 1 07-20-2003 07:00 PM
 Subscribe to our RSS feed
