Go Back   Jeepz.com > Technical Forums > All other Jeep models
This section Sponsored By
Old 08-04-2009, 05:03 PM
Angry 2000 jeep wrangler.suspension fix
Having a jerk to one side when driving on freeway when letting off gas, has a 4 inch lift with all the right stuff.any ideas?
View Public Profile Send a private message to %1$s Show BarryJoe gallery
Old 08-04-2009, 05:19 PM
Wrangl3r93's Avatar
Real Name: Matt League
Send a message via AIM to Wrangl3r93
Re: 2000 jeep wrangler.suspension fix
Is it jerking to the right?
The poster formerly known as Red93...
'93YJ 4.0HO, 33x12.50r15 Maxxis Mudder Buckshots, 4.5 RE extreme-duty lift w/ 1" BL, 4.11 gears, Aussie locked front, 1in transfer case drop soon to be replaced by SYE/cv shaft, 2 memphis 10's pushed by a memphis pr500, custom bumpers made by me
http://www.myjeepspace.com/wrangl3r93
http://www.tnvjc.org/index.php
View Public Profile Send a private message to %1$s Show Wrangl3r93 gallery
Old 08-04-2009, 05:25 PM
xt master's Avatar
Jeep :
Year :
Lift :
Tires :
TJ Wrangler
1997
Stock
31"
Real Name: Tony
Send a message via Skype™ to xt master
Do you have lockers?
View Public Profile Send a private message to %1$s Show xt master gallery
  #4 (permalink)
Old 08-04-2009, 06:23 PM
Wrangl3r93's Avatar
The reason I asked if it jerked to the right is my yj does the same thing when I let off. I've come to believe it's my suspension unloading because if I get on it in the lower gears it's pretty obvious as you can feel the front left start to lift,pulling me to the left, then the exact opposite reaction once the torque disappears. It's twice as bad if I don't press in the clutch, the engine braking providing torque in the opposite direction can throw me over a good 4 or 5 feet if I'm not careful. The few other lifted wranglers I've ridden in(yj's and tj's) have all had the same problem. As for a fix, check your control arm bushings in the rear I'm not sure what all can be done with the coil springs. On mine I plan to run a longer leaf spring perch when I put the ford 8.8 in to try and keep the springs from wrapping up. Important since I plan to run a turbo in the next year or two and the added power won't help.
  #5 (permalink)
Old 08-04-2009, 06:37 PM
SteelHeadz's Avatar
Official Supporter
Jeep :
Year :
Lift :
Tires :
CJ7/ AMC 360
1981
4.5
35x14.5 15 Pittbull Krawlers
Real Name: Mikey
Send a message via MSN to SteelHeadz Send a message via Yahoo to SteelHeadz
My analysis to this condition is that the steering linkage pulls and pushes as it collapses and retracts between the axle and the frame, where as the steering gear box is hard mounted on the frame and the steering linkage/ draglink is on the axle. The softer the blow collapsing, i.e. decelerating or braking will cause less pull to one side and the opposite goes on accelerating. Is this accurate?
Confucious says: Foolish man give wife a grand piano, Wise man give wife an upright organ.
View Public Profile Send a private message to %1$s Show SteelHeadz gallery
  #6 (permalink)
Old 08-04-2009, 07:19 PM
Wrangl3r93's Avatar
Hard braking vs soft braking doesn't affect how hard it pulls and braking from a coast causes no pull(at least not in my case). It's only when the engine applies power and lets off that it pulls one way or the other.
  #7 (permalink)
Old 08-04-2009, 08:14 PM
Bounty__Hunter's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
6"
36"
Could be some really worn control arm bushings, or a rear locker. The latter would likely bang when it locks/unlocks.
  #8 (permalink)
Old 08-05-2009, 11:55 PM
ya all your ideas are good. put on the lift today and found the left rear track arm bushing worn. going to replace the bushings then check it out. thanks
  #9 (permalink)
Old 08-23-2009, 09:12 PM
Real Name: Bryan
check your motor mounts too!
View Public Profile Send a private message to %1$s Show dewbrizzle gallery
  #10 (permalink)
Old 09-04-2009, 11:29 PM
88Wrangles's Avatar
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1988
6"
42"
Real Name: Matt Pyle
Send a message via AIM to 88Wrangles
Did that fix it? also make sure your air pressure is the same in all your tires.
View Public Profile Send a private message to %1$s Show 88Wrangles gallery 88Wrangles
  #11 (permalink)
Old 09-07-2009, 12:40 AM
Member
Jeep :
Year :
Lift :
Tires :
TJ Wrangler
1997
Stock
31"
Real Name: Don
check your front axle U joints. one that is frozen/binding will cause that.
View Public Profile Send a private message to %1$s Show volaredon gallery
2000 jeep wrangler for parts rebelxgirl069 Items for Sale, Trade, or Give Away 6 07-15-2009 09:30 AM
2000 Jeep Wrangler for sale judge09 Items for Sale, Trade, or Give Away 2 05-28-2005 10:35 PM
CA:2000 black soft top for a Jeep wrangler TJ-7 Items for Sale, Trade, or Give Away 0 05-19-2004 11:53 PM
Targa Top For 2000 Jeep Wrangler Hollieberry85 General Chat 1 07-20-2003 08:00 PM
