Welcome to Jeepz.com.
Results 1 to 5 of 5
    valey0531's Avatar
    valey0531 is offline Junior Member
    valey0531 is
    fixing my jeep
    Jan 2011
    9
    Type of Jeep
    Grand Cherokee
    97 Grand Cherokee Laredo 4.0 ltr 4x4 will not shift into overdrive.
    Hello everyone, I have a 97 grand Cherokee that is currently giving me some drivetrain problems. I have a code that keeps coming up that states that my circuit input is either to high or low to my throttle position sensor. I replaced the sensor and it keeps giving me the same two codes, sometimes together, sometimes separate. The actual problems that I am having is that it will not kick into 4th gear, or overdrive, while I approach cursing speeds. I tried using the OD OFF button on the dash but it does nothing. When the engine and trans gets to the speed where it usually shifts into 4th, it jerks like it wants to shift but stays in 3rd. I have consulted with some techs on the matter but they say that either there is something wrong with the wire and plug for the sensor, or the power train control module is malfunction which could lead to the transmission control module to malfunction and the reason why it is not shifting. Also, when u put it into drive and move at slow speeds and then come to a stop, it almost stalls and the battery gauge dips down. Sometimes it does stall and takes forever to turn back over. Any help on this matter would be much appreciated because I need this vehicle to last. The engine however does run strong for having 182,000 miles on it. The trans does shift perfectly fine between 1,2, and 3 gears. It just will not go into OD. Let me know guys, thanks!!
    - Kyle
    SteelHeadz's Avatar
    SteelHeadz is
    in need of gears for the front and rear axles. ;(
    Oct 2008
    Kerrville, TX
    5,839
    Type of Jeep
    CJ7/ AMC 360
    Re: 97 Grand Cherokee Laredo 4.0 ltr 4x4 will not shift into overdrive.
    Does it do it only when the lights are on or any other loads? or is it all the time regardless?
    valey0531's Avatar
    valey0531 is
    fixing my jeep
    Jan 2011
    9
    Type of Jeep
    Grand Cherokee
    Quote Originally Posted by SteelHeadz
    I do not believe it matters what is on. It seems to do all the time regardless what else is on. Any ideas?
    -Kyle
    SteelHeadz's Avatar
    SteelHeadz is
    Oct 2008
    Kerrville, TX
    5,839
    Type of Jeep
    CJ7/ AMC 360
    I would recommend that you check the TPS sensor connector for corroision or a poor connection and likewise for the PCM connectors just to verify that it's NOT as simple as that. There's a possibility that the governor pressure sensor could be malfunctioning as well causing the symptoms.
    Appleshack's Avatar
    Appleshack is offline Member
    Appleshack is
    gone fishing....right after work.
    Mar 2011
    The UP of Michigan
    31
    Type of Jeep
    Grand Cherokee
    This sounds really simple and I'm sure you did this, but I had the same exact problem and I put some Lucas in and the tranny fluid was low. Topped it off and it seemed to fix it.
  1. 95 Grand Cherokee Laredo won't start
    By skullfisher in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 10-12-2010, 06:47 AM
  2. 99 grand cherokee laredo.2 for now
    By itwontme in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-05-2010, 09:52 AM
  3. 94 Grand Cherokee 4WD/AWD 4L won't go into overdrive
    By jonathanstampf in forum CJ YJ TJ and JK
    Last Post: 10-18-2009, 09:34 PM
  4. 98 grand cherokee laredo 4.0l
    By behr in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 12-31-2008, 12:36 PM
  5. 96 grand cherokee hard shift problem
    By vp6799 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 05-06-2008, 10:20 PM
