Go Back   Jeepz.com > Jeep Articles, Guides, and Reviews > Jeep Tech > Brakes
This section Sponsored By
Comment
LinkBack Article Tools Display Modes
Bleed your brakes
Bleed your brakes
Terry Mason
Published by TerryMason
11-13-2005
Bleed your brakes
The brake system in your CJ works by using brake fluid to press together two front disc brakes, that squeeze a disc (the rotor) to slow you down. Over time air can get into your brake lines, and since it's relatively easy to compress air, when you go to step on the brakes, the air in the line will compress instead of the disc brakes squeezing and you won't stop.
Removing the air in your brake system isn't too hard. Have a look at the directions below.
By TerryMason on 01-26-2008, 08:56 AM
Step 1 - The materials
I managed to find this brake bleeding kit in a local parts store. It is a pretty simple setup that you should be able to make yourself. It has a hose that goes into a jar of brake fluid.
Step 2 - prep the master cylinder
First, take off the master cylinder lid, and top it off with fluid
By TerryMason on 01-26-2008, 08:58 AM
Step 3 - find the bleeder valve
locate the bleeder valve, and loosen it with a wrench.
  #4 (permalink)
By TerryMason on 01-26-2008, 09:00 AM
Step 4 - hook up the one man bleeder
Attach a hose to the valve and fully open the valve.
  #5 (permalink)
By TerryMason on 01-26-2008, 09:02 AM
Step 5 - get the air out
I put a coffee can under everything to catch any spilt brake fluid. You pump the brakes until there are no more bubbles visible in the clear tube, then run over and tighten the bleeder valve up again
Comment
Article Tools
HTML code is On
