This section Sponsored By
Old 04-12-2004, 05:57 AM
Member
I have a 1988 cherokee limited and I was replacing the ignition switch (working under the dash with all those freakin wires hanging around) and now my power windows don't work. Is that a fuse somewhere? Or did I just bump the wrong wire loose? I searched the schematic for a fuse location and I didn't find one. Any help would be appreciated. Thanks
View Public Profile Send a private message to %1$s Show irishsetter48 gallery
Old 04-12-2004, 04:37 PM
On the bottom row of the fuse box, there is a silver metal box (looks like a small relay) itīs a 30 Amp circuit breaker. You can pull the circuit breaker and test for power, with a volt meter or trouble light, with the key in the run position.
The wire from the ignition switch to the fuse block (circuit breaker) is orange. The orange wire also spplies current to the clock circuit, so if your clock is on, itīs probably the circuit breaker, if the clock is off (and the 6 amp fuse is good), itīs probably the wire or a connector.
View Public Profile Send a private message to %1$s Show MudderChuck gallery
