Old 07-26-2005, 02:01 PM
Bullet3600's Avatar
Send a message via AIM to Bullet3600 Send a message via Yahoo to Bullet3600
RE: On the road again
I pressure washed the engine over the weekend and no my 87 Cherokee with a 4.0 won't upshift and stays stuck in 1st gear. Everything worked fine before the wash. I sprayed some quick dry around the TPS but still no luck. Any help would be appreciated.
View Public Profile Send a private message to %1$s Show Bullet3600 gallery
Old 07-26-2005, 08:57 PM
Bounty__Hunter's Avatar
Moderator
Pretty common. Could be a bad TPS, they're easy to check with a multimeter.
Check here for some troubleshooting tips. I've got this same problem in my '88 MJ.
http://www.transonline.com/transdige...ers/index.html
Old 07-27-2005, 05:36 AM
Real Name: Joe Irvine
Send a message via ICQ to graewulf Send a message via AIM to graewulf Send a message via MSN to graewulf Send a message via Yahoo to graewulf
RE: Cruise Control?
also check the trans fluid.. i know its a long shot, but water in the fluid would cause shift problems.
When I Die, Bury me in my JEEP. 'Cause it's never been in a hole it couldn't get out of!
View Public Profile Send a private message to %1$s Show graewulf gallery graewulf
  #4 (permalink)
Old 07-27-2005, 07:11 PM
Bullet3600's Avatar
Thanks for the info. I will try those steps on Saturday when I make time. The Trans fluid is clean and a nice red, but was also wondering if some junk or something broke loose in the pan and clogged something. This is very frustrating having to share only one jeep with the wife.
  #5 (permalink)
Old 07-27-2005, 11:47 PM
LBR LBR is offline
Don't know this particular engine/tranny setup, but does this automatic have a vacumn actuated modulator? If it does, the pressure washing could have blown a rubber line off of the modulator. A lot of older trannys will not upshift if that vacumn line is not "talking" to the modulator. LBR
Plant the wheelie bars and let the games begin
View Public Profile Send a private message to %1$s Show LBR gallery
  #6 (permalink)
Old 07-29-2005, 10:08 AM
Bullet3600's Avatar
Well I changed the TPS and still no luck, Time for step 2.
  #7 (permalink)
Old 07-29-2005, 11:59 PM
RE: Re: Jeep Gov..?
Quote:
Did you check the fuse behind the glove box? There is one is the harness near the TCU, for the TCU (tranmission control unit).
View Public Profile Send a private message to %1$s Show MudderChuck gallery
  #8 (permalink)
Old 07-30-2005, 11:16 AM
Moderator
Pulling the fuse behind the glove box for the TCU should allow you to manually shift the tranny. This will rule out mechanical failure inside the slushbox.
  #9 (permalink)
Old 08-02-2005, 07:58 PM
Bullet3600's Avatar
Well the fuse checked out ok, does anyone know where the vacuum modulator is located on the trans?
  #10 (permalink)
Old 08-03-2005, 10:38 PM
RE: Spring compatability
There isnīt a vacumm modulator in the AW 4 that I know about.
Iīd check power first, there is a 7.5 amp fuse in the fuse block, the 15 amp fuse behind the glove box and a fusible link, probably near the starter relay, behind the battery.
Next check would be the TPS, what is your input voltage, output voltage and how does your ground wire test for resistance? 4 pole connector at the TPS. Normal input voltage is around 4.65 or so, no matter what the book says. The output voltage should be around 3.85 but the tranny will work just fine up till about 4 volts or so. The check is made with the plug connected ( straight pin through the wire), the ignition on and using the 4 pole plug (TCU) ground, not a chassis ground to test.
A TV (transmission Valve) cable adjustment, might also cause problems. But with a miss adjusted cable, it will usually eventaully shift. or have really soft slipping shifts.
Forum Jump
Message Board Statistics
Jeepz.com RSS2 Feed
