Old 10-09-2005, 12:04 PM
RE: How much of a motor mount lift is needed for a flat bell
I have a 1993 Grand Cherokee.
About a month ago, my fan and A/C stopped working. I checked the fuse inside the engine compartment, it looked OK (I did NOT replace it). I figured I'd let it go.
Last nite, I discovered my heat does not work either.
I'm guessing it's something in the control panel.
Any ideas would be greatly appreciated, before I decide to rip apart the dash board.
WindLaker
View Public Profile Send a private message to %1$s Show windlaker gallery
Old 10-09-2005, 01:45 PM
I'm looking at my "Haynes" repair manual. I wanted to 1) Check which fuse to check and 2) find out how to tear apart the dash.
I cannot find the fuse block! I have the one in the engine compartment, but I cannot find the one under the dash. I found the flashers, but they are by thenselves, not on the fuse block.
I'm am getting thouroughly confused by this project.
Old 10-09-2005, 04:58 PM
RE: Got it
I still haven't found the fuse box.
I did remove the blower motor, hotwired it - it does work.
Any other ideas? Buy a new heater control panel?
  #4 (permalink)
Old 10-10-2005, 04:06 PM
jules's Avatar
Does the fan come on at all? My fan would only come on when the knob was set to high. If this is the case, it's you blower resistor. Might want to check it anyway.
View Public Profile Send a private message to %1$s Show jules gallery
  #5 (permalink)
Old 10-10-2005, 05:37 PM
fuse panel is on the "side" of the dash when the passenger's door is open!
1995 Grand Cherokee V8 Selec-Trac
1997 Pontiac Trans Am WS6 Ram Air
American Muscle of Olean
View Public Profile Send a private message to %1$s Show 95blkzj gallery
  #6 (permalink)
Old 10-10-2005, 08:08 PM
97blkzj,
Thanks very much for the answer.
Unfortunately, all the fuses are good, and I still have no fan, A/C, heat.
Any more ideas, anyone? Buehler? Anyone? Buehler?
  #7 (permalink)
Old 10-10-2005, 09:20 PM
Jules,
I have no fan at all. No noise when I move the vent/def/off dial. No power when I push the A/C button.
WindLaker
  #8 (permalink)
Old 10-12-2005, 06:48 AM
Real Name: Joe Irvine
Send a message via ICQ to graewulf Send a message via AIM to graewulf Send a message via MSN to graewulf Send a message via Yahoo to graewulf
when you say the fuses are all good, did you actually check them with an ohmmeter? visual inspection is not good enough, as they sometimes blow right at the end where you can't see it.
When I Die, Bury me in my JEEP. 'Cause it's never been in a hole it couldn't get out of!
View Public Profile Send a private message to %1$s Show graewulf gallery graewulf
  #9 (permalink)
Old 10-12-2005, 08:18 PM
RE: CJ 5 vacuum diagram need help
Thanks for all the help, people. Unfortunately, I get the "Donkey" award for this one.
I had my neighbor take a look at it. What it was was this.
The center dial on the heater control panel was cracked on it's shaft. It felt like it was clicking (heat to vent to defrost), but it was actually slipping. It was stuck in the "OFF" position, and that is why nothing worked.
Thanks again,
WindLaker
Forum Jump
Message Board Statistics
 Subscribe in a reader
