Old 02-09-2007, 08:53 PM
Send a message via AIM to Psomion
Question on clutch fan pulley
Has anyone had thier clutch fan pulley fail on them? my 96 xj only has 80k miles and the pully siezed and pushed out fromt the bearings... The part from Jeep cost near $300 and I'm feeling lazy about going to a junk yard for a part that might do the same thing. would switching to an electric fan be ok if i just used a shorter serp belt and totally removed the actual pulley? Thanks for your thoughts
-Doug
Huntingdon Pa
1996 Jeep Cherokee
Desert Fish
View Public Profile Send a private message to %1$s Show Psomion gallery Psomion
Old 02-09-2007, 09:23 PM
TwistedCopper's Avatar
Real Name: Harry
Re: Question on clutch fan pulley
COnverting to an electric fan seems like a no brainer for you right now.
A worthwhile mod for many reasons, fuel economy and a slight boost in power are two of them.
Where are you in Huntingdon? My wife has a friend from Pole Cat Hollow...
Old 02-09-2007, 09:27 PM
Thanks.. I live in Barree.. about 7 miles west of the town of huntingdon and then 3 miles past alexandria. Middle of no where really (I live on a church camp property)
-Doug
Huntingdon Pa
1996 Jeep Cherokee
Desert Fish
  #4 (permalink)
Old 02-09-2007, 09:54 PM
Bounty__Hunter's Avatar
Moderator
Not much room for an electric, I'd check out www.car-part.com or find one online.
  #5 (permalink)
Old 02-09-2007, 10:27 PM
smell my dirty poodle's Avatar
mine whent bad on my cj. i just cut the clutch off and welded the fan directly to the shaft. clutch eliminated. I read an article saying electric fans dont move as much air as mechanical. Im sure thats debatable but I figure I would throw that in. I plan to go electric still. More power. Less gas
go to bed with an itchy butt... you are sure to wake up with stinky fingers
View Public Profile Send a private message to %1$s Show smell my dirty poodle gallery
  #6 (permalink)
Old 02-10-2007, 01:18 AM
http://www.angelfire.com/my/fan/electric.html
Look that over, I did it myself and it was pretty easier. If you can figure out a ziptie and a little bit of wiring then you're golden. Shouldn't cost more than $100 with new stuff.
1998 Jeep Cherokee 4.0 AW4 D30/C8.25
View Public Profile Send a private message to %1$s Show 98XJ gallery
  #7 (permalink)
Old 02-10-2007, 06:50 AM
Real Name: Harry
Nice write-up!
  #8 (permalink)
Old 02-10-2007, 06:52 AM
Real Name: Harry
Quote:
That's okay... I don't even know where "Pole Cat Hollow" is. I tried to mapquest her directions home to Pole Cat Hollow Rd but it wasn't even on the map
  #9 (permalink)
Old 02-10-2007, 07:16 AM
Sparky-Watts's Avatar
Banned
Quote:
The newer electric fans move as much or more air as mechanical. In fact, they move air more consistently than mechanical, also, since they run the same speed regardless of engine speed. A mechanical fan has only a small band of the engine RPM where they are efficient, hence overheating problems when running at low RPM's while crawling or in slow-moving road traffic.
View Public Profile Show Sparky-Watts gallery Sparky-Watts
  #10 (permalink)
Old 02-10-2007, 09:03 AM
Jeepr's Avatar
Electric fans hate mud..
View Public Profile Send a private message to %1$s Show Jeepr gallery
  #11 (permalink)
Old 02-10-2007, 11:59 AM
This is probably a sin to say here, but have to keep this jeep looking nice. Its the only car i own that my girl isn't ashamed of so it keeps my AMCs under her radar a little. Most of the mods at this point on the jeep will be strickly performance mods that she won't notice unless i hit the gas when shes around.
XJ98.. i actually came accross your write up via google prior to comming here. The ONLY problem I have with it is you still use the pully that the clutch fan was on.. and thats what is broken and $300. I can't remember the exact layout of the belt and was trying to figure if I could bypass that entire pulley somehow. I can't actually check at the moment (all this broke a week before i left for basic training... i'm stuck in arizonia now until april). I want to have the parts ordered and at my home so when i get back i'll have a running car the next day. Thanks again all.
-Doug
Huntingdon Pa
1996 Jeep Cherokee
Desert Fish
  #12 (permalink)
Old 02-10-2007, 12:24 PM
That wasn't my write-up but from a friend of mine. As far as a modified serp belt routing I saw a writeup of that somewhere and Ive been working on doing it myself becase my AC is dead so they put the alternator where the AC is and remove a couple pulleys.
Ive asked this guy what size belt he used and such but he hasnt gotten back to me. But heres a quote by him : "To get rid of the A/C compressor and move the alternator up, use a junkyard 4cyl commanche alt bracket/idler with slight modifications. Then measure the belt length and go to the parts store and get it. Easy and cheap to do.
My set-up has the clutch fan eliminated also."
One of these days when I get the time. Just make sure that everything is spinning in the correct direction, that you have enough tension on the belt so that it doesnt slip and not move anything, and you should be set.
  #13 (permalink)
Old 02-10-2007, 07:19 PM
Quote:
Thanx for the imput on the fan Ill feel much better going electric. Any brand you woud recomend for a 86 cj 258?
  #14 (permalink)
Old 02-10-2007, 09:57 PM
Banned
Depends on what you want to spend and how long you want it to last. You can spend a few bucks on a fan from a Ford Taurus in a junkyard, and mod it to fit and work, but you'll never be quite sure how long it will last, or you can do as I did and go the lazy and expensive way and get a Flex-A-Lite fan. My Flex-A-Lite bolted right up with no modifications, has a great warranty, and is more efficient than an older used Taurus fan. I can't remember off-hand what I paid, but it was around $200-$300 and well worth it, IMO. It can be wired to run automatically or be switched (so you can shut it off for water crossings), and it comes with a thermostat that will turn it on and off (I guess that would be automatically, huh? ) Anyway, mine works perfectly, keeps a rock steady temp no matter what speed I drive or what the outdoor temp is.
  #15 (permalink)
Old 02-11-2007, 05:06 PM
Thanx for the info, I think flex a light is a fan some of the military guys were experimenting/adding to the hum v. to combat overheating.Sounds like a good way to go.
Forum Jump
Message Board Statistics
 Subscribe in a reader
