Old 07-20-2007, 04:39 PM
Transfer Case Chain Noise
95 Jeep is making a loud grinding, grating noise. I believe it is coming from the Transfer case. I can see the chain and the noise appears to only happen when the chain acually rotates and what I would say as torque on the system. Coasting makes no noise and when in park eveything sounds fine, the engine sounds good as ever, all the noise happens when it is put in gear and driven.
Being able to see the chain seemed odd to me. Is that normal? Shoudn't the chain be fully encased and unseen because of lubrication and general protection? The Haynes repair manual doesn't give me enough information to tell for sure. I wonder if that's my problem...
View Public Profile Send a private message to %1$s Show hahaynes gallery
Old 07-20-2007, 07:15 PM
Send a message via AIM to LauraBoston Send a message via Yahoo to LauraBoston
Re: Transfer Case Chain Noise
rewind..how can you see the chain? does it happen in 4wd? how does the fluid look...and what kind of tcase?
wicked good dude
View Public Profile Send a private message to %1$s Show LauraBoston gallery LauraBoston
Old 07-20-2007, 08:12 PM
Sparky-Watts's Avatar
Banned
I wouldn't think being able to see the chain in the tcase at any time while the engine is running would be a good thing.
View Public Profile Show Sparky-Watts gallery Sparky-Watts
  #4 (permalink)
Old 07-20-2007, 11:32 PM
Hope this helps. Seeing should be believing....Attached are some picture I just took. I just layed on the ground on the drivers side, left is toward the front and right is toward the back, very accessable.
Is there a cover missing or has something fallen off? I thought the transfer case was a sealed box, so you never had to check the fluid. I can't imagine any fluid in mine right now.
Same noise in four wheel or two wheel drive....
transfer-case-chain-noise-copy-chain-view.jpg  transfer-case-chain-noise-copy-both-u-connections.jpg  transfer-case-chain-noise-copy-good-view.jpg
  #5 (permalink)
Old 07-21-2007, 12:33 AM
Bounty__Hunter's Avatar
Moderator
Bad news is you hosed the rear case half of the transfer case, blew a hole right in it. Good news it is rebuildable as the front case half doesn't look damaged. If you were close enough I have all the parts here to rebuild it.
Consider picking up a used one, make sure it's from a similar drivetrain so the input shaft will be correct. You could pick up almost any 231j if you knew how to swap your input shaft into the new one. They run about $200 and less around here.
  #6 (permalink)
Old 07-21-2007, 06:58 AM
Banned
Holy Cow!! Yeah, I'd say that's a problem!
  #7 (permalink)
Old 07-21-2007, 11:09 AM
Thanks for the knowledge. I'm really surpirse it didn't lock up. I'll see what I can find in here Charlotte.
The 2nd engine only has 30k on it, so, it's worth it to me to put a rebuilt or used ransfer case on in it. I figure the transmission will go in time but besides that I shoud be good to go for several more years...thanks again...
  #8 (permalink)
Old 07-21-2007, 10:02 PM
Send a message via AIM to SenorCole86
how does one go about doing that kind of damage?
1980 CJ-7 Renegade
Motorcraft 2150 Carb / GM HEI Ignition / 4.0 HO Head / Clifford Cam+Valve Train / Painless Wiring Harness / Bedlined Interior / 31" TRXUS M/T's / 1.25" Spidertrax Spacers/ and some indeterminate amount of suspension lift
I'm an auto mechanic who works on a doesn't need to know basis.
View Public Profile Send a private message to %1$s Show SenorCole86 gallery
  #9 (permalink)
Old 07-21-2007, 10:15 PM
Moderator
Looks as if it may have run dry on fluid, and the chain stretched and eventually slipped a tooth on the front output sprocket. There's not enough room between the case and sprocket for the chain to skip a tooth without breaking the case.
  #10 (permalink)
Old 07-23-2007, 12:24 PM
it's those new air cooled tcases...i'v seen'em
wicked good dude
  #11 (permalink)
Old 07-24-2007, 04:38 PM
Air cooled alright.
Any thoughts on driving it down the street besides a prayer and cross'n my fingers? It's seems that if I did pour anything on it, it would fly out every where and leave a nice trail of evidence....
  #12 (permalink)
Old 07-24-2007, 06:54 PM
Moderator
I recommend not driving it unless you wanna be replacing even more parts. It could damage the transmission should it continue like it is.
  #13 (permalink)
Old 07-25-2007, 12:54 AM
thanks.......
  #14 (permalink)
Old 12-16-2007, 06:16 AM
I have a 2000 TJ and I also have a problem with my t-case. Whenever I try to engage it I get is a grinding noise. I haven't blown a hole in my t-case (just yet). I do have fluid in it and it only happens when I have to abruptly accelerate. Any suggestions on what it may be?? Stretched chain, missing gear teeth, any help would be appreciated, thanks
View Public Profile Send a private message to %1$s Show Geep5 gallery
Forum Jump
Message Board Statistics
 Subscribe in a reader
