HELP! Front Axle
Ok I started noticing that my front passenger side axle was making a grinding noise. Then the other day I noticed that the tire was leaning top end in and bottom out. I figured it was because I needed an alignment so I wasn't too worried. Well I was switching tires today and realized once the tire was off the ground that I could wobble the tire and watch the end of the axle move around. But when I spin the tire I can see the front driveshaft move. I'm assuming I didn't break the front axle, but maybe it's u-bolts or something? Anyone have an Idea? I kinda need help as soon as possible. Also is it going to be that hard to fix? Thanks alot.
Jeep. On-road or off-road, it dominates.
