Old 03-28-2008, 04:53 PM
Real Name: JohnF
Cherokee ignition key cylinder replacement and noise question
My son and I got 2 Cherokees CHEAP. He drove the '89 home but had to pick up the '87 with a trailer because there was no key. Is there an easy to replace the ignition cylinder without the original key?
The '89 has a click in the rear axle relative to rotation, once per rev. Any ideas what that could be? Don't know what axle it has.
TIA
JohnF
View Public Profile Send a private message to %1$s Show JohnF gallery
Old 03-31-2008, 11:15 AM
Real Name: JohnF
Re: Cherokee ignition key cylinder replacement and noise question
OK, clicking was rear "U" joint. Completely gone so replaced it and noise is history.
Any ideas on ingition cylinder???
JohnF
Old 04-03-2008, 10:18 AM
Tilt Column Repair
Tilt Column Fix - Dale's Jeep Junk
Here are a couple of links for steering column R&R, you don't have to go all the way through, the cylinder is near the top (the beginning).
DO IT IN THE MUD!
View Public Profile Send a private message to %1$s Show MudderChuck gallery
  #4 (permalink)
Old 04-03-2008, 10:41 AM
Real Name: JohnF
Perfect thanks.
JohnF
  #5 (permalink)
Old 04-04-2008, 08:16 AM
The first couple of times through I put up a clean table (board on a couple of saw horses) and laid the pieces out in order. I also made a few notes. Not brain surgery but it can get confusing.
If you have trouble getting the cylinder out without the key there is a trick that I've never tried, that may or may not be relevant (I've always had the key).
DO IT IN THE MUD!
Forum Jump
Message Board Statistics
 Subscribe in a reader
