This section Sponsored By
  #21 (permalink)
Old 07-10-2008, 07:00 PM
mud4feet's Avatar
Re: just bought a 88 cherokee
Quote:
Originally Posted by IRPancake View Post
.........for 1200 i think it was a steal even with the small projects :)
I don't think you mentioned earlier what you paid! You're right, that was a steal!!!! Good luck gettin' 'er up to snuff! You've come to the right place.
View Public Profile Send a private message to %1$s Show mud4feet gallery mud4feet mud4feet's Arcade Awards Flash Poker Kullors
  #22 (permalink)
Old 07-10-2008, 07:45 PM
American_girl_728's Avatar
Real Name: Ashley
I got some black 'rust eliminator' paint or something from advance auto, guess I'll use that in the rear. Tomorrow we're running up to the junkyard and hopefully getting the little things it needs. How hard is taking off the harmonic balancer?
View Public Profile Send a private message to %1$s Show American_girl_728 gallery
  #23 (permalink)
Old 07-10-2008, 08:58 PM
Bounty__Hunter's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
6"
36"
Not hard, but you'll want to rent the balancer puller from the auto parts store.
  #24 (permalink)
Old 07-10-2008, 09:02 PM
IRPancake's Avatar
Member
Real Name: Andy
will do. I'll update you guys on how the trip goes. Going to bleed the cooling system before we head up there, hopefully it doesn't overheat on the way there
View Public Profile Send a private message to %1$s Show IRPancake gallery
  #25 (permalink)
Old 07-10-2008, 11:36 PM
IRPancake's Avatar
Member
Real Name: Andy
bled the cooling system, really easy to do, it took alot of distilled to fill it back up after opening that screw. Hopefully that helps out alot. Also pulled up the rear carpet and it wasn't pretty, there were actual holes through the rusted metal in a few places. How would one go about patching something like that up?
  #26 (permalink)
Old 07-10-2008, 11:58 PM
Real Name: Ashley
if you put all the rust spots together it makes up half of the entire back of the car if not more and at least two of the holes are big enough i can put my fist in them i think getting sheet medal and replacing the whole back floor is a good idea then there is no risk of missing a spot and allowing it to spread andy ^ thinks we should spray some rust stuff on it and patch where it is weak what do you all think?
  #27 (permalink)
Old 07-12-2008, 06:51 PM
IRPancake's Avatar
Member
Real Name: Andy
went to a junkyard today. They had alot of cherokee sports, none of them had the same type of overflow so I didn't get that, or a harmonic balancer, trackbar, or a fan shroud, all the things I really wanted to get but we got other little things it needed. I tried taking the trackbar off, but I couldn't get the part with the bushing off so I was going to remove the whole bracket it was connected to, but the bolts were a strange size (or I'm an idiot) and couldn't get it completely off. Is there a way to just unhook the part with the bushing?
  #28 (permalink)
Old 07-12-2008, 10:56 PM
Real Name: Ashley
ah new weather striping though yay, after the one piece (vertical)on the passenger side door there will be no more leaks. (hope you liked dinner)
  #29 (permalink)
Old 07-13-2008, 10:54 PM
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
6"
36"
To get the upper end of the trackbar off, remove the cotter pin and nut. Soaking with PB Blaster may help. Then strike the side of the bracket with a BFH where the stud on the end of the trackbar goes through, this will temporarily egg-shape the hole and break the trackbar loose. This stud is tapered the same as a tierod end which means taking it apart is as much a pain as working on steering.
  #30 (permalink)
Old 07-19-2008, 06:48 PM
IRPancake's Avatar
Member
Real Name: Andy
Ordered a new instrument cluster and got everything else it needs minus the trackbar and harmonic balancer and its running great, stop and go the other day and it hardly went above 2 second bar. I made a mold for a fiberglass shroud but its gonna look so bad lol. When I get a damn break from work we're gonna get that rear fixed and change out fluids, sparks plugs and it'll be good to go
  #31 (permalink)
Old 07-21-2008, 03:05 PM
Kanifler's Avatar
Real Name: Pierre
Hey change that track bar-you hear that clunk? Yah no good!
View Public Profile Send a private message to %1$s Show Kanifler gallery
  #32 (permalink)
Old 07-21-2008, 09:05 PM
IRPancake's Avatar
Member
Real Name: Andy
the clunk is from the trackbar? Its coming from the right front wheel
  #33 (permalink)
Old 07-23-2008, 01:44 PM
IRPancake's Avatar
Member
Real Name: Andy
went to bleed the brakes today. The bleeder screws are rusted in there and I ended up breaking off part of the nipple. I emptied the master cylinder before that and I tried just filling it up with new fluid and it feels the same...
  #34 (permalink)
Old 07-25-2008, 08:17 PM
IRPancake's Avatar
Member
Real Name: Andy
I have a feeling I might get back the money I've put into this car. Once we get rid of the rust in the rear, we can recarpet it (pepboys sells lenghts of carpet that matches the color really well) and refinish the plastic pieces. Also added some nice driving lights:
  #35 (permalink)
Old 07-26-2008, 04:17 PM
IRPancake's Avatar
Member
Real Name: Andy
Damn the harmonic balancer seems to have gotten a little worse . Also will getting these bushings fix the trackbar issues
eBay Motors: Jeep Cherokee Wrangler Front Track Bar Bushings Poly ZJ (item 350043832586 end time Jul-30-08 18:54:47 PDT)
  #36 (permalink)
Old 07-26-2008, 06:03 PM
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
6"
36"
New bushings will not fix the worn out tierod end of the front trackbar. Many jeepers remove oem trackbars for an adjustable unit, you can pick them up used in good shape.
Just bought a 95 Cherokee Sport, what's the first thing jaymed1998 Cherokee, Commander, Wagoneer and Liberty 8 05-09-2005 06:52 AM
Bought the CJ! toyman CJ YJ TJ and JK 6 02-19-2004 06:32 PM
Bought a new toy!!!!! xxjas12xx General Chat 1 12-27-2003 07:20 PM
Just bought a YJ Chris C CJ YJ TJ and JK 6 07-20-2003 08:00 PM
Just bought an XJ! BillR Cherokee, Commander, Wagoneer and Liberty 4 07-20-2003 08:00 PM
