08-28-2008, 02:31 PM
Member
Moving up to 4inch lift
So right now I have 3 inches of lift. I'm looking at adding some spacers up front and a block in the back to get an extra inch of lift so I can upgrade to 33's. Does anyone know if I need an SYE for this. I see its recommended for anything 4 inches or higher. can I get away without one as they seem to be around 200 bucks. is there anything else I should keep in mind when moving up to 4 inches?
1990 Cherokee 3" Skyjacker lift w/ cold air intake, exhaust
08-28-2008, 04:00 PM
Moderator
Re: Moving up to 4inch lift
You shouldn't need one on a '90 XJ, they weren't real necessary until '97 when they needed a SYE or TC drop for any amount of lift.
You can also use shackles to get the rear lift, either aftermarket or MJ shackles.
09-03-2008, 12:43 PM
Member
Are there any strength or rear axle movement problems I need to worry about if I decide to use shackles instead of a 1 inch block.
Would it be better to actually get rear leaf springs (not add a leaf) that create the 4 inches?
09-03-2008, 02:42 PM
Moderator
Shackles will allow for less axelwrap than lift blocks, so springs will last a little longer.
Replacement spring packs are probably the best method of lifting the rear, it will be a little stiffer but the springs will last longer than stock springs.
09-04-2008, 01:57 PM
Member
Well I took a look at the prices of new spring packs and for one inch of lift I don't feel like paying 200-500 bucks.
At this point I'm leaning towards just buying 1 inch steel blocks.
If I went with shackles are there any concerns that they would break?
09-04-2008, 03:31 PM
Moderator
Generally no. They are not a weak link. Blocks on the other hand, if not properly made and installed, can crack and/or spit out. They also increase axlewrap.
09-04-2008, 04:56 PM
Member
Ok, I think I will look into installing the shackles.
As for the front end I was just going to get the correct size washers from a hardward store and use them to create my extra one inch of lift up front. As anyone tried that before?
09-04-2008, 05:47 PM
Moderator
The rubber donuts from the hardware store fit, but don't last. Look for a pair of stock coil isolators, they run almost .75" thick. Some places sell 1" spacers I believe.
09-04-2008, 07:32 PM
Member
Thats why I'm going with large washers to build exactly an inch. I looked at spacers but the ones I saw didn't seem to be made out of strong materials, I'm also going for a cheap upgrade. My buddy used hockey pucks on his exploer but I think the washers will work just fine.
09-13-2008, 12:56 PM
Member
So I found a write up here for creating the coil spring spacers
XJ Coil Spacer Lift
The spring connects to the bump stop. When i take the spring off does the thing the spring connects to at the top also fall out? How is this held in?\
I have circled the part I am talking about in the picture. You will notice that they put the new spring spacer above the bump stop/coil spring holder. I already have a sky jacker lift should this be the same or is the only way to find out to take the spring off?
09-13-2008, 12:58 PM
Member
Ok so apparently I attached the pic. Anyone have a tip on how to get it so it displays in the post?
| Thread Tools |
| Display Modes |
Linear Mode
