This section
Sponsored By
10-06-2008, 03:26 PM
Real Name: Matt Davis
Engine Dying and Jerking
I have a 1994 Jeep Cherokee Sport and lately it will kind of jerk driving down the road and sometimes it will just die. It doesn't happen on a consistent basis or a pattern. It just happens. Sometimes it won't crank right back up...like its starving for gas. I'm about to change the fuel filter but would like any ideas or suggestions anyone might have
10-07-2008, 11:31 PM
Moderator
Jeep :
Year :
Lift :
Tires :
Re: Engine Dying and Jerking
Remove the throttle body and sensors, give the TB a good bench cleaning.
10-09-2008, 08:21 AM
Can you elaborate more...I'm not a mechanic at all.
10-13-2008, 09:50 PM
Real Name: Mix
Hey guys, I have a 1995 Grand with the V-8 and it is doing basically the same thing. Sometimes when I try to accelerate, it hesitates and bucks, and occasionally when I let off the gas to start slowing down, the rpms drop off and often dies. Ain't good when one is trying to make a turn! And as with mattd's, it don't always do it. I fugure the TPS is going. Am I on the right track? Any help is appreciated. Thanks.
10-14-2008, 10:46 AM
Member
When something of this nature happened to me it was a bad catalytic converter.
The 95 Grand sounds like a misfire but I might be off on that one.
1990 Cherokee 3" Skyjacker lift w/ cold air intake, exhaust
10-14-2008, 11:55 AM
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1989
3.5" Fabtech SUA
35" BFG mudders
Matt, if it seems it is choking for gas maybe you need to change out the fuel filter. When the vehical is sitting or has been what ever debree it has filtered settles to the bottom of it and you get a fairly consistant flow of fuel but after time or bumps it will be pulled into the filter again and start deminishing fuel flow. New filters are cheap 10 buck or so and easy to change.
Just my 2 cents.
Bacon
10-15-2008, 07:58 AM
Bacon,
I changed the fuel filter this weekend and within a day it died 4 times on me. Now since then it's only sputtered once or twice. I am at a lost. I think the catalytic converter might be a problem but that doesn't explain the engine jsut dying driving down the road...no jerking or anything jsut dead...
10-15-2008, 01:12 PM
Member
Quote:
Originally Posted by mattd
Bacon,
I could be wrong on this so someone correct me, but if the exhaust gases cant get out because the cat had gone bad it might cause your jeep to die.
10-22-2008, 08:18 PM
Moderator
Jeep :
Year :
Lift :
Tires :
CJ7/ AMC 360
1981
4.5
35x14.5 15 Pittbull Krawlers
Real Name: Mikey
Do you have any diagnostic trouble codes(Check Engine Light) on?
10-20-2009, 10:08 AM
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1990
two inch body lift
31"
Real Name: Jeff
Can't afford another cat. What would be better, rod the cat or cut it out and replace it with an appropriate length of pipe?
10-24-2009, 12:49 PM
Have a Comanche that had the same problem and after much searching, the problem was the stud that the negative (ground) battery cable attaches to was loose in the cylinder head where it screws in.
To fix, remove the nut and lock washer holding the cable on, unscrew the stud, put some kind of thread locker on it and re-install to proper torque value or just tighten it up good and tight then put the battery cable back on it and tighten up the nut.
Good luck!
12-24-2009, 06:11 PM
Jeep :
Year :
Lift :
Tires :
Real Name: Brad
Good luck!
I agree.....check grounding...intermittent problems are normally ground in my experiance.
12-26-2009, 08:41 AM
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1990
two inch body lift
31"
Real Name: Jeff
I replaced my coil and the problem I mentioned earlier in this thread went away 90%. I did notice that the housing that the coil sits in looks to be aluminum. The aluminum seems to be somewhat corroded so I am going to try to clean the mounting surface for better contact and see if that eliminates the problem.
| Thread Tools |
| Display Modes |
Linear Mode
