1051889
I typically wore out two sets of fronts to one set of rears. And there arnīt any speed limits around here. One thing you might look at, is the front brakes from a limited, I donīt know for sure, if itīs just in the export model or not, but they were some beefier.
I had pretty good luck with Raybestos, semi-meatalic, riveted. Though the semi metalic did have tendancy to wear the drums a little.
I donīt know how much time you spend in the water, but a little sand in there, will wear out the brakes quick. I pulled the drums, dumped out the crud and hosed off the brakes and backing plates, after most every mud hole.[addsig]
DO IT IN THE MUD!
