This section Sponsored By
Old 06-25-2009, 01:01 AM
Real Name: Jeff
Send a message via AIM to 03grand
03 Grand Cherokee Axel seal
I have been noticing some grease on the RR wheel over the past few weeks. I have been watching it until tonight when it feels like something is dragging. i also felt the LR wheel and it was warm but when I went to the RR it was HOT. I am assuming that the seal is bad but I have been hearing a lot about the bearings.
Will I have to open the rear to release the axel and how hard is it to change the bearings. I dont have a press if I need one and am trying to avoid going to a shop.
All help is welcome!!
People say, "it's a jeep thing, you wouldn't understand!", well, I got your jeep thing and now I can't get rid of it!!
View Public Profile Send a private message to %1$s Show 03grand gallery
Old 06-25-2009, 07:50 AM
SteelHeadz's Avatar
Official Supporter
Jeep :
Year :
Lift :
Tires :
CJ7/ AMC 360
1981
4.5
35x14.5 15 Pittbull Krawlers
Real Name: Mikey
Send a message via MSN to SteelHeadz Send a message via Yahoo to SteelHeadz
Re: 03 Grand Cherokee Axel seal
REMOVAL
  1. Place transmission in neutral.
  2. Raise and support vehicle.
  3. Remove wheel and tire assembly.
  4. Remove brake caliper and rotor.
  5. Remove nuts holding axle retainer plate to axle tube from the rear of the axle flange.
  6. Pull axle shaft from the axle with Slide Hammer 7420 and Adapter 6790. Mount the adapter to the axle with lug nuts. NOTE: The axle bearing race is normally loose in the axle tube.
  7. Drill a shallow hole into soft steel axle bearing retaining ring with a 3/8 in. drill bit . Use a drill depth stop to avoid marking the axle.
  8. With a cold chisel cut the retaining ring across drilled hole.
  9. Slide retaining ring from axle shaft.
  10. Remove axle bearing from the shaft with, a press and Splitter 1130 placed between the seal and bearing .
  11. Remove seal from axle.
  12. Remove retaining plate from axle shaft.
Yes , you will need a press for this job..
Confucious says: Foolish man give wife a grand piano, Wise man give wife an upright organ.
View Public Profile Send a private message to %1$s Show SteelHeadz gallery
Old 06-25-2009, 09:47 PM
Real Name: Jeff
Thanks for the help, I am on the phone with the shop as I type. $175.00 as long as the axel is ok...lol
95 grand cherokee Pops Items for Sale, Trade, or Give Away 1 05-07-2009 11:46 PM
Cherokee or Grand Cherokee? Choices? Questions ECT... CJatGuy Cherokee, Commander, Wagoneer and Liberty 11 12-29-2004 07:14 PM
Grand Cherokee Pitman and Cherokee Driveshaft blazntn Items for Sale, Trade, or Give Away 0 06-23-2004 05:52 PM
'88 cherokee rear axle seal replacement XJNick Cherokee, Commander, Wagoneer and Liberty 2 07-20-2003 08:00 PM
93 Grand Cherokee V8 pandres2002 Cherokee, Commander, Wagoneer and Liberty 2 07-20-2003 08:00 PM
