This section Sponsored By
Old 10-04-2009, 07:57 PM
Real Name: Angel
Just got a 97' cherokee sport
Automatic,4x4,4 door. It's going to be a daily driver, however I love the lifted look. I want to go with a 4 or 4.5 lift. Are there bolt on kits fir 4.5 or do they require bracket welding? Any lift anyone care to recommend? I've looked around and lots of mixed reviews. Thanks in advance
View Public Profile Send a private message to %1$s Show Jeep4 gallery
Old 10-05-2009, 04:54 PM
Jeep :
Year :
Lift :
Tires :
Cherokee
1989
rusty's long arm
35 bfgs for the street. 33 ltbs and 33 boggers for wheeling
Real Name: chance stitzell
Re: Just got a 97' cherokee sport
there are many 4 to 4.5 inch lifts for xj's. rusty's offroad makes nice lift kits. i would recomend not going over 4 inches unless you go with a long arm lift otherwise the ride quality goes way down.. i would also say get full replacement rear springs instead of add a leafs and blocks. it costs a little more but the ride will be much better and the leaf pack will last longer and flex better.. what size tires are you looking to run? a 4 inch lift should clear 31's or 32's depending on the width and rim and how hard it will be wheeled..
when in doubt put her to the wood!
View Public Profile Send a private message to %1$s Show blown XJ gallery
Old 10-06-2009, 12:46 AM
Real Name: Angel
I want to stay away from add ons and blocks. Maybe 3.5 or 4 is best. I was just looking fir a complete kit that requires no air tool or welding. Is like to go with 32" tires but dunno the backspacing/offset are for these cars. I'm guessing at 3.5 I shouldn't need a SYE?
  #4 (permalink)
Old 10-06-2009, 02:40 PM
The Rubicon Express 3.5" super ride kit is very nice and rides well. Get one with rear replacement springs and not a add a leaf.
View Public Profile Send a private message to %1$s Show Rmart30 gallery
  #5 (permalink)
Old 10-06-2009, 04:54 PM
Bounty__Hunter's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
6"
36"
You will need a 4" or 4.5" kit to clear 32" tires, lots of good kits out there. You may be able to get by with simply lowering the transfer case crossmember 1/2" instead of needing a SYE.
FYI you can do a hack and tap SYE for under $100 and often just bolt in a stock front CV driveshaft in the rear after installing a flange adapter. I install them often.
  #6 (permalink)
Old 10-06-2009, 09:26 PM
Jeep :
Year :
Lift :
Tires :
Cherokee
1989
rusty's long arm
you wont need a sye with a 4 or 4,5 inch lift.. i have friends running 6+ inches of lift with out sye.. just drop the tcase 1/2" OR 1" and you will be fine
  #7 (permalink)
Old 10-07-2009, 01:36 PM
Real Name: Angel
Thanx guys. I was looking at the rubicon 3.5 lift. I'm guessing it disent come with shackles? Would I need an adjustable track bar? Forgive my ignorance, I'm sort of new to this. I'm trying to figure out what else I would need to have a streetable xj and minor mud trails. Possibly use 32" tires with 15x8 Mickey Thompson sidebiters.
3.5" Super-Ride Suspension System with Leaf Springs for 84-01 Cherokee XJ with Dana 35 Rear Axle by Rubicon Express
  #8 (permalink)
Old 10-07-2009, 11:15 PM
xjmarc's Avatar
Jeep :
Year :
Lift :
Tires :
XJ
1997
Too Much and Not Enough
35 MTZ's
Real Name: marc benton
I ran the Rubicon 4.5 with 33s for a while and liked it. Only bad thing about the Rubicon stuff is you have to use their bushing if you ever need to replace them. I would recommend Rusty's, drop the t-case 1" and run the stock driveshaft.
View Public Profile Send a private message to %1$s Show xjmarc gallery
  #9 (permalink)
Old 10-08-2009, 11:20 PM
Real Name: Angel
That's load off of my mind, but why is it that every site says SYE "required" For 4.5 lifts? Is it just to cover their ass and make money?
  #10 (permalink)
Old 10-09-2009, 01:50 AM
Jeep :
Year :
Lift :
Tires :
Cherokee
1989
rusty's long arm
alot of companys recommend it instead of a tcase drop bracket. with the sye you wont lose that 1" on ground clearance under you tcase. i run a 1" tcase drop and a sye with about 9" of lift on my xj without any vibrations.
  #11 (permalink)
Old 10-09-2009, 03:34 AM
Real Name: Angel
9" wow! You're my hero, haha! Thanks!
  #12 (permalink)
Old 10-09-2009, 11:03 PM
Jeep :
Year :
Lift :
Tires :
Cherokee
1989
rusty's long arm
well its soon going to grow to ten inches maybe eleven inches with 37 or 38 inch tires
  #13 (permalink)
Old 10-09-2009, 11:22 PM
Real Name: Angel
That's awesome. Let us know the weather up there!
  #14 (permalink)
Old 10-23-2009, 01:12 AM
xjmarc's Avatar
Jeep :
Year :
Lift :
Tires :
XJ
1997
35 MTZ's
Not sure I'd want to go that high. Hope you're not running stock axles. I was breaking shafts with my 33's. Of course most people don't drive like me. I'm running 60's now with 7-8" of lift and 35's and the full width axles help a lot with stability, but I'm still pretty top heavy.
  #15 (permalink)
Old 10-23-2009, 08:35 PM
Jeep :
Year :
Lift :
Tires :
Cherokee
1989
rusty's long arm
as of now i have a stock 30 in the front with a d44 in the rear.. soon i will have a 44 in the front and either a 14 bolt or 60 in the rear
  #16 (permalink)
Old 10-25-2009, 05:11 PM
LRwrnglr's Avatar
Real Name: Connor
Send a message via MSN to LRwrnglr
Whats the scoop on the Rough Country lifts?
03' Liberty, Rusty's K&N tube and filter, 2.5" Rusty's Suspension Lift, 31" Hercules Trail Diggers
View Public Profile Send a private message to %1$s Show LRwrnglr gallery
  #17 (permalink)
Old 10-27-2009, 08:50 PM
xjmarc's Avatar
Jeep :
Year :
Lift :
Tires :
XJ
1997
35 MTZ's
For the money you can't beat the Rough Country stuff but if you can spend a little more and get a complete kit like Rusty's, Rubicon Express and if you can afford it Rock Krawler. The Rock Krawler triple threat is sick but at a price.
  #18 (permalink)
Old 10-29-2009, 04:18 PM
Jeep :
Year :
Lift :
Tires :
Cherokee
1989
rusty's long arm
rough country lifts are ok.. if it was me i would save up a little bit more and go with a rusty's lift.. there lifts ride alot better and work better offroad. they do alot more off and on road testing (abusing) of their parts before they put the kit up forsale.. i run a rustys lift and love it!
  #19 (permalink)
Old 10-29-2009, 09:10 PM
tow_hook's Avatar
Jeep :
Year :
Lift :
Tires :
Cherokee
1993
8"
35"
Real Name: brian
Quote:
the rusty's kit i had was not so good, the rear springs sagged in 2 months, no customer service, either ... i had to buy the extra leafs, then 2 years later snaped them on the road, bent like a S.... the front / rear springs others have bought went south as well.... so no more rustys, cheap is cheap... i bought all r.e.& tear flex and it holds up well !
can't speak for r/c, or rock krawler
Current rides:
62"cj3b, getting restoflyed :)
95"yj, now on 33's
93"xj, 35" needs rockers, and a front locker
02"wj, 33" km2's, and h.o.
" bent, broke & twisted ( 4x4 club ) " are you?
http://www.bbnt4x4.org/
View Public Profile Send a private message to %1$s Show tow_hook gallery
rims for a 96 cherokee sport AKASHAJEEP Cherokee, Commander, Wagoneer and Liberty 7 12-27-2003 07:09 PM
Cherokee sport?? Joopin Cherokee, Commander, Wagoneer and Liberty 2 08-29-2003 06:53 PM
99 Cherokee Sport Problems doylebr Cherokee, Commander, Wagoneer and Liberty 1 07-20-2003 07:00 PM
2000 cherokee sport polittdj CJ YJ TJ and JK 0 07-20-2003 07:00 PM
94 Cherokee Sport stalls mareshel Cherokee, Commander, Wagoneer and Liberty 1 07-20-2003 07:00 PM
 Subscribe to our RSS feed
