This section Sponsored By
Old 11-06-2009, 12:08 PM
Real Name: Douglas
1991 cherokee engine rebuild
i'm rebuilding an engine for my 91 cherokee and i'm trying to give myself a migrain figuring the timing chain/gear enigma. according to the "book" the cam gear mark sets at the 12 o'clock position and the crank gear mark sets at just before the 3 o'clock position. if this were my cj it would be a no brainer as the marks would line up and the rest would fit. could one of you wiz-bang fellows clarify this quandry?
View Public Profile Send a private message to %1$s Show osnixpero gallery
Old 11-06-2009, 12:17 PM
SteelHeadz's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
CJ7/ AMC 360
1981
4.5
35x14.5 15 Pittbull Krawlers
Real Name: Mikey
Send a message via MSN to SteelHeadz Send a message via Yahoo to SteelHeadz
Re: 1991 cherokee engine rebuild
Ahhmm, which engine are you reffering to?
View Public Profile Send a private message to %1$s Show SteelHeadz gallery
Old 11-08-2009, 05:02 PM
Real Name: Douglas
4.o 6 cyl
  #4 (permalink)
Old 11-08-2009, 07:55 PM
SteelHeadz's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
CJ7/ AMC 360
1981
4.5
Real Name: Mikey
This is the 4.0 timing marks.
  #5 (permalink)
Old 11-09-2009, 07:58 AM
Real Name: Douglas
the timing marks i know. the positioning of them is the question. the chiltons says that for only the 90-91year modles the marks are to be set with the cam mark at the 12 oclock position and the crank mark at the 230 or so position (near three oclock per book) so that there is 15 pins between the marks. is this something new in engine rebuilding or do it old school and set the marks as in your picture?
  #6 (permalink)
Old 11-10-2009, 12:49 AM
carnuck's Avatar
Jeep :
Year :
Lift :
Tires :
Comanche
1988
6"
33/9.50/15s
Quote:
Childrens is the problem. Take what they say with a grain of salt. I use the overlap method of setting chains. With the #1 at top dead center, either the #1 rockers are at overlap (roll the motor either way and the intake or exhaust start to open/close) or #6 (#4 on 4 cyls) is. I do that with the rockers loose so the piston/valves don't make contact.
View Public Profile Send a private message to %1$s Show carnuck gallery carnuck
  #7 (permalink)
Old 11-10-2009, 06:52 AM
SteelHeadz's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
CJ7/ AMC 360
1981
4.5
Real Name: Mikey
I agree, Top dead center is your verification for setting up the timing . That illustration is from the factory service manual.
  #8 (permalink)
Old 11-11-2009, 08:11 AM
Real Name: Douglas
that is what i was going to do in the first place, run the #1 up to tdc as i would for my cj. but what is the significance of the 15 pins between the timing dimples and will setting the timing gears as in the pic affect timing as this engine (when finished and installed) will be timed by the computer not by moving the distributor? i just want to get it right on this motor. i wish it was as easy as my cj!
engine rebuild or not?????? markr CJ YJ TJ and JK 10 11-11-2009 09:45 AM
1991 Cherokee looking for new home kycanuck Items for Sale, Trade, or Give Away 2 07-12-2009 03:00 PM
1991 Cherokee laredo xratedj Items for Sale, Trade, or Give Away 1 07-12-2009 02:58 PM
engine rebuild mandarrin CJ YJ TJ and JK 1 01-03-2004 05:15 PM
engine rebuild advice hoobness CJ YJ TJ and JK 5 07-20-2003 07:00 PM
 Subscribe to our RSS feed
