Re: 86 cherokee laredo
My dyslexia strikes again, looked at you model year 86 and saw 89 the first time. LOL What engine do you have?
Overheating in traffic (especially with a new radiator) is often a bad mechanical fan clutch. And/or your auxiliary fan isn't coming on, it should kick in when the temperature gets much above 212-220 (temp. gages lie a lot).
Getting the air out can be a pain. I squeeze the top radiator hose together a half dozen times with the motor running.
Possible your heater valve is gummed up, part of the flow that helps to purge air is through the heater valve and the coolant tank.
Also possible your radiator cap is gummed up and not releasing the pressure like it should.
In my experience you can have multiple things going on that add up.
The bottom radiator hose is the one from the drivers side bottom of the radiator to the water pump, 1 1/2" diameter (I think), kind of hard too mis looking from the bottom up. The view of the bottom radiator hose can be blocked looking down. If you squeeze it together, you should feel a spring in it. If you can squeeze it flat without using much pressure, it can cause grief at high RPM's (it my collapse).
DO IT IN THE MUD!
