    Vortexbetty's Avatar
    Vortexbetty is offline Junior Member
    Jul 2010
    Portland, OR
    14
    92 Jeep Cherokee
    I'm new, so this is more of a "breaking my post cherry" than anything.
    I recently acquired a 92 Cherokee with 192K miles on it. I love the damn thing and it's been solid, but when I took it up into the mountains, it overheated on my way up - was about 100 degrees out and my temp gauge must have been stuck because it WAS fine, but it went from "fine" to "hotter than the surface of the sun in a very short time. Before I could pull over my radiator blew up.
    $200 tow bill and a radiator replacement later, it's "fine" again, but now it seems to be running rougher.
    I'm a clueless tard when it comes to the cause and effect - though I'm slowly learning - but does that make sense? Could the one overheating - even though I pulled over RIGHT the heck away - have made my engine sad?
    Or am I just more aware of it's shortcomings now that it broke down on me...
    Just curious as to opinions on that.
    Thanks.
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,083
    Re: 92 Jeep Cherokee
    When you say "running rougher", like a misfire or lack of power?
    Jul 2010
    Portland, OR
    14
    It seems louder and it's 'dieseling' where it didn't used to do that. It just "sounds" rougher.
    No misfire or lack of power that I can tell.
    It's quite possible that I'm just noticing noise where I didn't before, but I can't be sure.
    (Paranoid! Haha)
    Jul 2010
    Portland, OR
    14
    I've decided after a few days that, yes, it is running rougher, but I'm not sure why. It's running, though, and that makes me happy. I'll be scheduling it for an oil change when I get paid, and maybe have my friends' neighbor (he's a bit of a gearhead) take a look at it to see what else he can suggest.
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,083
    See if you can get the PCM scanned for misfires and or DTC's.
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,040
    Could be a blown head gasket.
  7. #7
    jakbob's Avatar
    jakbob is offline Senior Member
    Nov 2005
    Naples, FL
    267
    do the key dance if you are throwing a CEL code
    completely offensive, denominational, gender-biased, very original...sig line
    1995 Jeep Cherokee Sport w/ 4.0 HO. 3 inch lift put on by previous owner. shooting for 5 inch spring packs in the back instead of 3 inch shackles...
  8. #8
    Jul 2010
    Portland, OR
    14
    Quote Originally Posted by SteelHeadz View Post
    Gonna see what I can find out at earliest opportunity for sure.
    Quote Originally Posted by Bounty__Hunter View Post
    Doesn't seem like that...
    Quote Originally Posted by jakbob View Post
    I so don't know what that means. LOL
  9. #9
    82CJ7JEEP's Avatar
    82CJ7JEEP is offline Senior Member
    Jul 2010
    Orlando, Fl
    209
    I tend to agree with bounty hunter, one of my friends has a cherokee sport, 4.0 automatic. Overheated it one time and had the smallest warp in the head, took a while for enough water to make it to the oil to know for sure. But after he replaced the water pump and before the blown head gasket(warped head) really showed it self it also ran rough.
  10. #10
    jakbob's Avatar
    Nov 2005
    Naples, FL
    267
    the key dance is where you put the key in the ignition, switch it to on, then to off, back to on, back to off, then back to on and leave it there... then the check engine light (CEL) will flash out the codes... like if the code is 12 it will go FLASH PAUSE FLASH FLASH. then just look up all the codes and it should give you an idea what the problem is
  11. #11
    Jul 2010
    Portland, OR
    14
    Ok so I did the key dance...and that's when I realized that I have no dash lights that work. None of the warning lights that is...they don't come on at all when I first turn the key like they typically do.
    I am also fairly certain that the computer that runs my Cherokee is that of a "Speak and Spell". Only not that sophisticated.
  12. #12
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,083
    I would check all the fuses first. Im not convinced that the PCM is the culprit. I could be wrong however, the cluster inputs varies by function, meaning, at least the Airbag warning lamp and the ABS should at least turn on with the initial key on and do a self check since they are an input to the cluster from 2 different modules and not from the PCM. Makes sense?. My first choice of diagnostics would be the connections in the back of the cluster then the ignition switch circuits, particularly the key on circuit.
  13. #13
    Jul 2010
    Portland, OR
    14
    I think I'll check the fuses soon - I'm in the middle of a hell move into Portland which will change my commute from "nearly an hour each way in my poor geriatric jeep" to "I get to walk 5 minutes". Can't wait to be moved....dreading the actual MOVE. Haha.
    I love my poor jeep - and will be glad when I can give it some more attention after this weekend.
    I'd like to add that I REALLY appreciate all the input I've gotten. Thank you.
  1. 2004 Jeep Grand Cherokee Cherokee,10" lift, GPS, TV's,System $13,300
    By gjs14 in forum Items for Sale, Trade, or Give Away
    Last Post: 03-07-2010, 05:41 PM
  2. Wanted: 89-91 Jeep Cherokee Laredo or Special Edition Cherokee [near WV]
    By rebelxgirl069 in forum Items for Sale, Trade, or Give Away
    Last Post: 07-12-2009, 04:21 PM
  3. TONS of Jeep and 4x4 stuff, CJ7, postal Jeep, Cherokee
    By GaryMB in forum Items for Sale, Trade, or Give Away
    Last Post: 10-15-2005, 09:35 PM
