Welcome to Jeepz.com.
Results 1 to 5 of 5
Thread: Problem?
    Kkcwk10's Avatar
    Kkcwk10 is offline Junior Member
    Kkcwk10 is
    has no status.
    Nov 2010
    4
    Type of Jeep
    2010 Grand Cherokee
    Problem?
    I dont know if this is a problem or not. I have a Grand Cherokee with the standard quadra trac 1 4x4 system. When ever i make a left or right turn and turn my wheel as far as it goes i hear a louad squeaking sound comming from the front wheels or something up front. This happens like when im in parking lot or parking grage at very slow speeds. Just wondering if it just cuz im turnig the whell all the way or what ? I really dont know
    If any one has any sugestions please let me know.
    82CJ7JEEP's Avatar
    82CJ7JEEP is offline Senior Member
    82CJ7JEEP is
    getting real excited for the stroked 302 build
    Jul 2010
    Orlando, Fl
    214
    Type of Jeep
    CJ7, AMC 360
    Re: Problem?
    Check the power steering fluid, on mine if the fluid is low the pump will squeal, progressively louder the farther I turn.
    MudderChuck's Avatar
    MudderChuck is offline Senior Member
    MudderChuck is
    has no status.
    Jul 2002
    1,382
    Re: Problem?
    Is it coming from the tires or the belts? I've had a belt that is a little loose, squeal when I turned the wheel, the power steering pump causes more drag. Many four cylinder Jeeps actually has a pressure switch in the power steering pump to bump up the idle a little during a turn, larger displacement engines, don't need it, but the drag is still there.
    Could be your alignment is a little out.
    Could be just normal tire drag, the front suspension is set up so the steering wheel tries to center itself during a turn. Part of the geometry of a normal front end geometry. The angle of the tires fight each other a little, part of the self centering design. Seems to be a little more pronouncd in many 4X, likely because they engineer the self centering design to work when in 4X (under load) also.
    DO IT IN THE MUD!
    Kkcwk10's Avatar
    Kkcwk10 is
    has no status.
    Nov 2010
    4
    Type of Jeep
    2010 Grand Cherokee
    Re: Problem?
    Thanks for the answers. il check the power steering fluid and belts.
    Bounty__Hunter's Avatar
    Bounty__Hunter is
    working on his new WK
    Nov 2002
    Southern Illinois
    12,249
    Type of Jeep
    YJ Wrangler
    Re: Problem?
    Sounds like a worn or dry CV joint in a front axleshaft. It's a 2010, take it to the dealership.
  1. cry 8.25 problem
    By greengoblin97 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-28-2010, 05:07 PM
  2. Possible problem
    By 94YJGUY in forum CJ YJ TJ and JK
    Last Post: 07-22-2009, 06:05 PM
  3. 93 AX-5 to a 95 or 96 AX-5 problem!
    By 93YJ in forum CJ YJ TJ and JK
    Last Post: 08-04-2008, 10:09 PM
  4. RB1 Problem
    By reynolds in forum General Chat
    Last Post: 09-28-2006, 12:13 AM
  5. problem!!!!!!!!!
    By MudderChuck in forum CJ YJ TJ and JK
