Welcome to Jeepz.com.
Results 1 to 3 of 3
    jaber's Avatar
    jaber is offline Member
    jaber is
    has no status.
    Mar 2003
    Arizona
    63
    1058415
    my question is will a distributor out of a '77 360cc work in the '88 360 to eliminate the dist. brain box? or do i have to replace the module? :-? :-x [addsig]
    1-\'51 Willys truck
    1-\'51 Willys Wagon
    1- \'74 CJ5,
    1-\'75 J20 Wrecker
    2-\'77 J10 p/u
    2-\'79 Cherokees
    1-\'85 Grand Wagoneer
    1-\'88 Grand Wagoneer
    I DO IT FULL SIZED....
    MudderChuck's Avatar
    MudderChuck is offline Senior Member
    MudderChuck is
    has no status.
    Jul 2002
    1,382
    1058911
    I don“t know what the smog test requirements are where your at. First question is why do you want to disable the control module. Are you having problems?
    I don“t know for sure, but having messed with similiar setups, a vacumn advance type distributor and a Dodge ignition module, used as a bypass for the stock system, is possible with similiar models, easy and inexpensive. I“m guessing you have a carburated motor?[addsig]
    DO IT IN THE MUD!
    jaber's Avatar
    jaber is
    has no status.
    Mar 2003
    Arizona
    63
    1059050
    no smog needed here, sometimes it runs just fine, the next time you try it could be dead. no power to the coil. a couple of days later it works again, and there's no patern to it. yes its carbed. :-?
    edited by: jaber, Mar 10, 2003 - 07:57 AM[addsig]
    1-\'51 Willys truck
    1-\'51 Willys Wagon
    1- \'74 CJ5,
    1-\'75 J20 Wrecker
    2-\'77 J10 p/u
    2-\'79 Cherokees
