Page 1 of 2 12 Last
    simple2029's Avatar
    simple2029 is offline Member
    Mar 2012
    34
    98 4.0 Liter timming
    Hello all i have a 6cyl 4.0liter i know the pcm is static timing and i cant change it but i got my jeep for my mom who is on dialices due to kidneys failing.
    My obd2 said a lot of bla bla..
    what i put in new.
    Plugs wires ign coil distrib cap rotor and cam sensor.
    Crank case sensor. i hallowed the cat since it was cloged.
    I put in mas air flow thing and the little rubber hose was good.
    There are on more codes.. the jeep idles ok
    but has a random stall.
    I was told to use the obd2 and see if the pcm was going bad and the ignition timing is 10.0 to 19.50 at idle
    at 2000 rpm its 40 to 42.
    Any in put please advise....
    Is that timing do high or low. ?
    i have no codes and the temp dont matter.
    But $400 for another pcm is way a lot of money for m.
    simple2029's Avatar
    Mar 2012
    34
    Re: 98 4.0 Liter timming
    Can the timing 10 through 19.50 cause the jeep to stall?
    Jester32's Avatar
    Jester32 is offline Senior Member
    Nov 2010
    Alberta. Canada
    1,546
    That's normal timing. My Cherokee usually sits at about 15-19 at idle and will hit 40 at Rpms.
    simple2029's Avatar
    Mar 2012
    34
    So the timing droping to 10 is no worry? I was told the 19.50 is to rich and is flooding the motor..
    But if its normal im sooo happy.. I saw to zip tie thebpcm connectors in tight .. so ill try that since i have many ties. And i saw using 1/4 screws also can help the pcm.
    Any info on these things?
    Jester32's Avatar
    Nov 2010
    Alberta. Canada
    1,546
    Nope 8-10 is normal. But the fluctuations should be smooth if it's irratic timing has nothing to do with mixture. It's when it's burned. All my big block Chevys are locked down at around 35 degrees all the time. It takes a lot of timing to stall an engine. I would look at all the PCM grounds and connections. Make sure the pins are tight etc.
    Jester32's Avatar
    Nov 2010
    Alberta. Canada
    1,546
    Not sure on the screws as all my controllers are plastic wrapped and not mounted with anything. Just ran a separate ground.
  7. #7
    simple2029's Avatar
    Mar 2012
    34
    Im making a lock in thing to keep the 3 plugs allll the way in. the grounds i can find are all really good. I will lock the plugs in with my strap/ zip thing and ill look again for a bad ground and post back.
  8. #8
    simple2029's Avatar
    Mar 2012
    34
    I took the pcm off and and duck taped a old tee shirt behind it.
    In front i pluged the connectors in.
    Now the space between the coolant jug ans the pcm connectors i put some cut cardboard to make a good force keeping the connectings tight. I can only pray this works.
  9. #9
    simple2029's Avatar
    Mar 2012
    34
    I was taking mom to the hospital ER and jeep stalled.. ong.. so keeping force on the plugs is not a fix..
    Any advice besides swaping the pcm since money is very tight .. Or is there any test i can do for the pcm. Or a after market pcm thats cheaper. ?
  10. #10
    Jester32's Avatar
    Nov 2010
    Alberta. Canada
    1,546
    Hope moms ok? Are there any dtcs. Any other symptoms.
  11. #11
    simple2029's Avatar
    Mar 2012
    34
    No codes i got a brand new obd2 pro from discount. i sold my only rifle to buy it.
  12. #12
    simple2029's Avatar
    Mar 2012
    34
    I just added an extra ground from the motor to the frame. the guy at part store said it cant hurt to try it. if this dont work i gona get the pcm... that will suck... wow $400 bucks...
  13. #13
    Jester32's Avatar
    Nov 2010
    Alberta. Canada
    1,546
    I wouldn't chuck parts at it. With the reader display freeze frame data
  14. #14
    simple2029's Avatar
    Mar 2012
    34
    I don't understand what you mean by the freezer display are you saying look for specific item or .. o b d 2 is saying everything is fine.
  15. #15
    Jester32's Avatar
    Nov 2010
    Alberta. Canada
    1,546
    Freeze frame data is data that's stored in the PCM before and after events. Can you view live data on the obd2 pro. Do you have access to a fuel pressure gauge.
  16. #16
    simple2029's Avatar
    Mar 2012
    34
    Yes sir the low psi is 50 and high is 55 ish... fuel psi is great.
  17. #17
    Jester32's Avatar
    Nov 2010
    Alberta. Canada
    1,546
    What did you gap your plugs to.
  18. #18
    Jester32's Avatar
    Nov 2010
    Alberta. Canada
    1,546
    Check and clean the asd relay and fuse terminals.
  19. #19
    simple2029's Avatar
    Mar 2012
    34
    Plugs are 35 all new with wires and ig coil and cam/crank censors. Every fuse is good. i checked.
  20. #20
    simple2029's Avatar
    Mar 2012
    34
    The asd relay looked good when i chwcked it. But for 4 bucks ill pop a new one.
Page 1 of 2 12 Last
  1. 88 YJ 2.5 TBI Timming Nightmare
    By ThorBuilt1 in forum CJ YJ TJ and JK
    Last Post: 02-11-2009, 08:31 PM
  2. 4.0 liter St 6 YJ photos
    By 88YJ6 in forum CJ YJ TJ and JK
    Last Post: 01-23-2008, 12:09 AM
  3. 4.0 liter performance
    By 85zebracherokee in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 03-23-2004, 12:48 AM
  4. 2.5 Liter engine
    By vavs in forum Items for Sale, Trade, or Give Away
    Last Post: 03-03-2004, 12:05 AM
  5. 2.5 liter to a 5.7 ??????
    By ryankopecki in forum CJ YJ TJ and JK
