Results 1 to 4 of 4
06-16-2012, 06:30 PM #1
1994 cherokee jumpstart brain teaser
I left my lights on and killed my battery then I went to jump start it and it would not turn over no matter how long it charged.So i took out the battery put a full charge on it put back in and still nothing then I had it tested and it was like new because it is.Next i checked the fuse box and two fuses were blown the ignition and the alternator both 60 amp fuses both replaced I also replaced the starter relay and still nothing i turn the key and it wont turn over so now its down to the starter and solenoid witch come together before i take it out and check/replace does anybody have any other ideas and have you heard of a starter going out from a jump start because before i left the lights on it ran and started perfectly by the way its a 1994 jeep Cherokee 4.0 thanks any input would be very helpful
06-19-2012, 03:56 AM #2
Did you hook up the jumper cables correctly? If you did i'd also lean toward your crank postion sensor, if that goes you'll have a no start.
Sent from my Devour using JeepzJust
Empty
Every
Pocket
06-19-2012, 10:07 PM #3
Re: 1994 cherokee jumpstart brain teaser
how clean are your terminals good connections are key
ALL I OWN ARE JEEPS!
54CJ3B ,76DJ5RHD , 81DJ5RHD, 88XJ , (It's)93XJRHD(Alive), 06KJ ,
06-20-2012, 07:57 PM #4
Have you tried starting it at the relay? Good chance you've blown some fuses and there are plenty.
1994 cherokee door lock
By dwynlln in forum Cherokee, Commander, Wagoneer and LibertyReplies: 2Last Post: 07-03-2010, 09:52 AM -
1994 Grand Cherokee For Sale - $2900 OBO
By judge09 in forum Items for Sale, Trade, or Give AwayReplies: 0Last Post: 07-19-2007, 10:24 AM -
1994 Cherokee Country For Sale
By risson in forum Items for Sale, Trade, or Give AwayReplies: 1Last Post: 08-25-2005, 02:54 PM -
1994 JEEP CHEROKEE STALLING
By RAVEN13xxx in forum CJ YJ TJ and JKReplies: 2Last Post: 07-20-2003, 07:00 PM
LinkBack URL
About LinkBacks
