Welcome to Jeepz.com.
Results 1 to 10 of 10
    PanchoJeep's Avatar
    PanchoJeep is offline Junior Member
    PanchoJeep is
    has no status.
    Jan 2010
    23
    How adjust front sway bar links ?
    How much do you tension them ?
    Do you tension them at all ?
    What ?
    Thanks
    ZJ, bought it new in '92. I6 / AW4; 191,000 miles; 2" lift; 31" BFG's; K/N air; Hella fogs; Borla header; JET power chip; 130% throttle body; goose and grouse blood on carpet.
    steady.foot's Avatar
    steady.foot is offline Senior Member
    steady.foot is
    a dirt digger
    Oct 2011
    central maine
    359
    Type of Jeep
    YJ Wrangler
    Re: How adjust front sway bar links ?
    No tension in the sway bar links.
    If you want to drive a sports car, Buy a mustang.
    PanchoJeep's Avatar
    PanchoJeep is
    has no status.
    Jan 2010
    23
    If you have tensioned your sway bar links, then what handling/riding characteristics would that produce?
    steady.foot is
    a dirt digger
    Oct 2011
    central maine
    359
    Type of Jeep
    YJ Wrangler
    your rig would tend to lean towards the side that is shorter. For instance. If you make the drivers side shorter it will pull down on the drivers side frame while pushing up on the pasenger side.
    PanchoJeep's Avatar
    PanchoJeep is
    has no status.
    Jan 2010
    23
    You are correct--no adjustment on sway bar links.
    Have a vibration that seems like wheel hop.
    Changed wheels/tires front to rear, same vibration.
    Replaced all 4 tie rod ends, same vibration.
    Am stumped.
    steady.foot is
    a dirt digger
    Oct 2011
    central maine
    359
    Type of Jeep
    YJ Wrangler
    What do you have for tires. Even an unbalanced or wrongly balanced tire on the back can make it shake.
  7. #7
    PanchoJeep's Avatar
    PanchoJeep is
    has no status.
    Jan 2010
    23
    Quote Originally Posted by steady.foot View Post
    BFG 31x10.50 A/T; Ranchos & 2" Teraflex lift.
    By "on the back", do you mean rear tires ?
    Asking, because, while steering wheel has some wobble,
    the big majority of the vibration seems to be coming from the rear.
    Have attached pics of rear control arm bushings.
    Attached Images Attached Images
  8. #8
    Jester32's Avatar
    Jester32 is offline Senior Member
    Jester32 is
    locked and loaded lets get stuck
    Nov 2010
    Alberta. Canada
    1,548
    Type of Jeep
    Cherokee
    Driveline angle issue?
  9. #9
    Utah_jeepster's Avatar
    Utah_jeepster is offline Moderator
    Utah_jeepster is
    back on the hunt for the cheep hydro set up.
    Jun 2003
    Sun Lakes, Arizona
    3,107
    Type of Jeep
    TJ Wrangler
    Have the tires checked for balance, rotating them might shift the "bad" tire around but still a slight vibe is hard to track down without first eliminating the tires completely. If once they are checked its time to lift the jeep and start prying on upper and lower control arms and ball joints and tie rod ends looking for play. The jeep has to be off the ground, wheels removed and suspension floating, supported by the frame only. Don't forget to check track bars. Once all steering components have been check, its drive line and u-joints...fun fun.
    blatant jokessubliminal sarcasmsexual innuendo
  10. #10
    steady.foot is
    a dirt digger
    Oct 2011
    central maine
    359
    Type of Jeep
    YJ Wrangler
    [QUOTE=
    [/QUOTE]
    Yes
  1. Front Sway Bar Links
    By ledyo in forum CJ YJ TJ and JK
    Last Post: 08-12-2011, 12:59 PM
  2. front sway bar links
    By Team Twisted Off Road in forum CJ YJ TJ and JK
    Last Post: 02-18-2010, 07:14 PM
  3. New sway bar links
    By wrangleramp88 in forum CJ YJ TJ and JK
    Last Post: 01-08-2009, 03:52 PM
  4. Need info on front sway bar links
    Last Post: 01-01-2009, 04:01 PM
  5. sway bar links
    By steve1109 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-12-2006, 10:44 PM
