Welcome to Jeepz.com.
Results 1 to 5 of 5
    firestarter's Avatar
    firestarter is offline Member
    firestarter is
    has no status.
    Nov 2009
    San Francisco
    63
    Type of Jeep
    Cherokee
    What is this component?
    Okay so this is gonna sound really dumb but I guess I can't search for something if I don't know what it is. As you can see from the pic I have quite a leak on the 2000 XJ. I gather that the small component on the left is the oil pressure switch but what is the larger one on the right? In older models I assume this is the distributor.....
    Anyways, with all the leaks can someone please let me know what all gaskets I should be ordering?
    Thanks in advance,
    -Matt
    Jester32's Avatar
    Jester32 is offline Senior Member
    Jester32 is
    locked and loaded lets get stuck
    Nov 2010
    Alberta. Canada
    1,548
    Type of Jeep
    Cherokee
    The one on the right is the cam sensor/ oil pump drive. There is a gasket under there. Looks pretty wet higher up is your valve cover leaking to.
    firestarter is
    has no status.
    Nov 2009
    San Francisco
    63
    Type of Jeep
    Cherokee
    Re: What is this component?
    Quote Originally Posted by Jester32 View Post
    Thanks. Yeah it's all kind of a mess under there. I replaced the valve cover gasket a few months ago but never really cleaned it up. Last weekend in wiped off all the excess oil and the only fresh oil left is around these two components so I'll have to make a run to the stealership (so I hear).
    I've been using "Engine Shine", are there any better products to cleanup really really old caked on oil?
    Thanks,
    -Matt
    Jester32's Avatar
    Jester32 is
    Nov 2010
    Alberta. Canada
    1,548
    Type of Jeep
    Cherokee
    I use the mopar engine shampoo works great. Spray on and let sit for 15 min. Wash off. Not sure if a dealer will sell it though as its industrial supplies.
    54cj3b's Avatar
    54cj3b is offline Senior Member
    54cj3b is
    Tired of having cancer
    Aug 2009
    Evergreen,Colorado
    1,522
    Type of Jeep
    Willys cj3b
    diesel or kerosine in a spray bottle spray down eng , let sit 15 min hose down to rinse
    cleans the toughest grime away
    ALL I OWN ARE JEEPS!
    54CJ3B ,76DJ5RHD , 81DJ5RHD, 88XJ , (It's)93XJRHD(Alive), 06KJ ,
