    92__cherokee's Avatar
    92__cherokee is offline Junior Member
    Oct 2012
    helenwood,tn
    20
    front drive shaft
    Will it hurt anythang if I remove the front drive shaft in my 96 grand Cherokee for better mpg its gotta 4.0 auto trans and full time 4x4 transfer case
    if parts aint flyin, you aint tryin
    steady.foot's Avatar
    steady.foot is offline Senior Member
    Oct 2011
    central maine
    523
    Re: front drive shaft
    Shouldn't hurt anything to remove it. But i doupt that it will help your mpg. The frond axles and gears are still turning. I took the driveshaft out of a 93 GC that i had and didn't see any diference
    If you want to drive a sports car, Buy a mustang.
    Oct 2012
    helenwood,tn
    20
    Ok jw I did it too my 85 Chevy and noticed a big difference
    TrailRatedRN's Avatar
    TrailRatedRN is offline Senior Member
    Aug 2011
    Springboro, Ohio
    1,869
    How big is a big difference?
    Oct 2012
    helenwood,tn
    20
    Went from 4mpg too between 8-10 when ya keep your foot outta it
    Baron97TJ's Avatar
    Baron97TJ is offline Junior Member
    Mar 2013
    4
    It's because your 85 had locking hubs so it didn't spin full time like jeeps do.
  7. #7
    carnuck's Avatar
    carnuck is offline Senior Member
    Jan 2009
    Seattle
    917
    The full time tcase (NV249) in the Grand Cherokee will explode it's viscous coupler if you remove the front driveshaft. If you convert to a NV231 or NV242 you can put it in 2wd to save gas.
    '87 Comanche 4x4 lifted 5 1/2" on 33" tires 4.0L/AW4/NP242 $3500
    Perfect combination but too small to haul my Grand Kids and wife in.
  8. #8
    Oct 2012
    helenwood,tn
    20
    Thank y'all for the advice
  1. cheerokee front drive shaft
    By west747 in forum CJ YJ TJ and JK
    Last Post: 04-28-2004, 04:50 PM
  2. Lining up the front drive shaft...
    By MOngo1970 in forum CJ YJ TJ and JK
    Last Post: 11-25-2003, 10:14 AM
  3. Does anyone know the length of a front drive shaft for.....
    By berettajeep in forum Cherokee, Commander, Wagoneer and Liberty
  4. front drive shafts...
    By ajfrank43 in forum CJ YJ TJ and JK
  5. External torx sizes,front drive shaft
    By Snitty in forum CJ YJ TJ and JK
