    PatrickPresti's Avatar
    PatrickPresti is offline Junior Member
    Apr 2011
    16
    1999 Jeep Cherokee XJ 4.0 Distributor Installation
    Hi Guys,
    Just rebuilt my engine on a 1999 Jeep Cherokee XJ 4.0. Does anybody know of a good procedure on how to install the distributor on the engine. I know that the engine has to be set for the #1 cylinder at TDC on the compression stroke. Any recommendations where the rotor should be located relative to the #1 cylinder would be great. I can't find any instructions that are very clear...
    Thanks,
    Pat
    greg92jeepxj's Avatar
    greg92jeepxj is offline Official Supporter
    Apr 2013
    Staten Island n.y.
    1,832
    Quote Originally Posted by PatrickPresti View Post
    Hi Guys, Just rebuilt my engine on a 1999 Jeep Cherokee XJ 4.0. Does anybody know of a good procedure on how to install the distributor on the engine. I know that the engine has to be set for the #1 cylinder at TDC on the compression stroke. Any recommendations where the rotor should be located relative to the #1 cylinder would be great. I can't find any instructions that are very clear... Thanks, Pat
    From my 1992 jeep FSM is the procedure . Should be the same for the 1999.
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    Also, there should be a hole on the bottom of the distributor housing and a hole on the tone plate inside close by where the sensor wiring comes out to the side. You can use this alignment hole by placing an Allen wrench or pin in the hole to keep it in place as you line up the shaft down to the notch on the engine side. Remove the pin before you install the sensor and rotor. The rotor should be pointing to the number 1 plug wire on the distributor.
  1. 1999 Jeep Cherokee Sport
    By Zombie Jeep in forum Items for Sale, Trade, or Give Away
    Last Post: 01-01-2013, 12:15 PM
  2. Replies: 1
    Last Post: 09-21-2012, 01:54 PM
  3. Jeep cherokee xj sport
    By Stalefishsk8er in forum General Chat
    Last Post: 12-08-2010, 05:26 PM
  4. Jeep Cherokee XJ Rock Crawler
    By FatherTime in forum Items for Sale, Trade, or Give Away
    Last Post: 08-07-2010, 08:20 AM
  5. 1999 Jeep Cherokee For Sale with Rubicon 4.5 lift
    By 78lotus in forum Items for Sale, Trade, or Give Away
    Last Post: 01-09-2005, 07:22 AM
