p0522 engine oil pressure sensor
jack kourie
I have grand cherokee 2014, and the check engine light is on so I put the scanner and it gave (p0522 engine oil pressure sensor circuit low), I erased it but it came back again after driving,
so how can I resolve this problem ?
How is your oil pressure?Gauges? Is your oil light coming on? Wouldn't want to drive it without oil pressure, Will cause damage. issues I read about with this jeep, could be oil sending unit,oil pump, i've even read about the filter housing needing to be replaced. If you had values you could test the sensors. From what I read this jeep is riddled with issues. Is it not under warranty? Brand new vehicle I would spam the hell out of the dealership
not positive, but might be around the oil filter housing area. Is where I would start my search
