Welcome to Jeepz.com.
Results 1 to 7 of 7
    SEMPERFIOX's Avatar
    SEMPERFIOX is offline Junior Member
    SEMPERFIOX is
    has no status.
    Apr 2003
    1
    1066259
    MY 97 JEEP HAS PROBLEMS STARTING-I HAVE TO TURN IT OVER SEVERAL TIMES BEFORE IT WILL START-ALSO IT WILL STALL ON CORNERS WHEN THE GAS TANK IS LOW-IT HAS LESS POWER THAN IT DID A YEAR AGO. I DID A SYSTEM CHECK AND ALL I GOT WAS CODD 55-WHICH MEANS END OF CODES-NO ONE KNOWS WHATS WRONG-I'VE ACTUALLY HAD OTHER PEOPLE WITH THE SAME YEAR/MAKE/MODEL TELL ME THEY HAVE THE SAME PROBLEM :-D [addsig]
    dingus's Avatar
    dingus is offline Look at my website.
    dingus is
    has no status.
    Aug 2002
    PA USA
    2,292
    Type of Jeep
    Grand Cherokee
    1066265
    sounds like a fuel delivery problem - pump, relay, filter, etc...
    -nate[addsig]
    utjeepn's Avatar
    utjeepn is offline Junior Member
    utjeepn is
    has no status.
    May 2003
    1
    1066527
    I had the same problem starting my '98 Cherokee. It was the fuel pump.[addsig]
    Bounty__Hunter's Avatar
    Bounty__Hunter is
    working on his new WK
    Nov 2002
    Southern Illinois
    12,249
    Type of Jeep
    YJ Wrangler
    1066632
    Our '98 XJ developed the same 'stalling in turns when tank is low' problem. I think it's common.[addsig]
    jeepmaster's Avatar
    jeepmaster is offline Senior Member
    jeepmaster is
    has no status.
    Nov 2002
    Colorado
    1,240
    1066658
    mines doing the same thing, they think its either a bad after cat o2 sensor or a fuel pump[addsig]
    Summit County, Colorado - 96 XJ - Magnaflow exhaust, K & N filtercharger, H4 conversion, MT/R's on 767's, safari rack, hot blonde and an Australian Shepherd riding shotgun
    EddyB's Avatar
    EddyB is offline Junior Member
    EddyB is
    has no status.
    Jun 2003
    3
    1071097
    Check up on the recall list for the XJ. The stalling out in left turns/fuel delivery problem is a factory recall. And then, go harass a dealer..........[addsig]
  7. #7
    mujaman's Avatar
    mujaman is offline Senior Member
    mujaman is
    has no status.
    Feb 2003
    California
    265
    1071844
    i had the exact same problem with my 97 cherokee this winter. all that needed to be replaced was the fuel filter (which unfortunately requires the gas tank be dropped) and spark plugs (but maybe not in your case). i'd say try the fuel filter first... worked great for me. its started on the first crank ever since then.[addsig]
    '97 4.0L XJ - ARB Bull Bar w/ Warn M8000 Winch, IPF Lighting, Rusty's 3" Springs, OME Shocks, AEV 16" Wheels, Goodyear 32" ATs, Yakima Rack, Flowmaster, K&N, Rocky-Road Step Rails, Alpine/Pioneer Sound, more to come...
