Results 1 to 3 of 3
Thread: knocking noise in front end
11-27-2003, 07:16 PM #1
I have a 99 xj limited when i turn the wheel eitherway i get a loud knocking noise. I replaced the u-joints on both sides. I am thinking it is a ball joint but i am possitive if anyone knows or had the problem i am having give me some advise it is starting to really annoy me.
1999 jeep cherokee limited, air intake, trottle body spacer new modifications and lift kit coming soon.
11-27-2003, 07:36 PM #2
Sounds like the front track bar. Tighten both ends, very tight, and make sure the upper track bar mount is tight to the frame.
11-27-2003, 07:55 PM #3
I have already checked the track bar its not that. I think it might be a lower ball joint. ill have to lube it up and turn the wheels to see if that is the problem.
LinkBack URL
About LinkBacks
