Welcome to Jeepz.com.
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    conejo1's Avatar
    conejo1 is offline Member
    conejo1 is
    has no status.
    Oct 2002
    32
    1042704
    The heater in my 85 cj-7 suxs..all I want is some type of a 12volt plug-in heater..anyone know of a brand that worxs well..?? [addsig]
    TerryMason's Avatar
    TerryMason is offline Administrator
    TerryMason is
    too big to fail
    Dec 1999
    Virginia Beach VA
    5,713
    Type of Jeep
    TJ Wrangler
    1042713
    Never found one that was worth a darn. I'd start by finding all the drafts in your Jeep and plugging them.
    I've heard lots of people swapping the blower motor from a full size Blazer into their Jeep, and it's supposed to be a huge improvement.
    Terry[addsig]
    conejo1's Avatar
    conejo1 is
    has no status.
    Oct 2002
    32
    1042715
    ..gracias, senor..[addsig]
    MudderChuck's Avatar
    MudderChuck is offline Senior Member
    MudderChuck is
    has no status.
    Jul 2002
    1,382
    1042717
    Might help to check your thermostat. Sometimes they get removed in the summer and forgotten about in the winter, untit it gets really cold. I put a second heater out of an old 151 military in the back (with a twelve volt motor), it really helps along with a 190 deg. thermostat. I´ve got a stand heater, gas flame type that I never installed, always make me a little nervous to think about the flame and gas in the passenger compartment.[addsig]
    DO IT IN THE MUD!
    conejo1's Avatar
    conejo1 is
    has no status.
    Oct 2002
    32
    1042738
    I think you are correct, I am going to purchase a 12-volt heater .. then put one of those "dusters" behind the seats ( those windows that strap to the roll-bar behind the seats) to make the cab area smaller...[addsig]
    TerryMason's Avatar
    TerryMason is
    too big to fail
    Dec 1999
    Virginia Beach VA
    5,713
    Type of Jeep
    TJ Wrangler
    1042742
    Good idea with the duster, never thought about that myself[addsig]
  7. #7
    Greencuke's Avatar
    Greencuke is offline Senior Member
    Greencuke is
    has no status.
    Sep 2002
    bagdad
    412
    1042749
    i have a duster im looking to get rid of, let me know if ur interested[addsig]
    you better run Terror! Im comming for you!
  8. #8
    chinard's Avatar
    chinard is offline Senior Member
    chinard is
    has no status.
    Aug 2002
    Toronto
    268
    1042750
    Actualy, i like the idea of swapping in a blazer blower motor.
    There seems to be plenty of heat coming out, just not enough air pressure behind it to fill the cabin. (Also, the stock blower sounds like hell)
    Does anybody have any details such as part numbers or install notes on the blazer swap?[addsig]
    \'82 CJ-7 - AMC 258 -
    Mods: Weber Carb, Borla Catback, Juicebox TFI, 31\" BFG AT, Powermaster 150a alternator, H4 headlights, blazer heater motor conversion, WORKING gas gauge.
    Now with 80% less rust!!!
  9. #9
    chinard's Avatar
    chinard is
    has no status.
    Aug 2002
    Toronto
    268
    1042752
    Nevermind...
    I found the link for the blazer blower motor swap http://www.off-road.com/jeep/tech/body/heater.html[addsig]
  10. #10
    conejo1's Avatar
    conejo1 is
    has no status.
    Oct 2002
    32
    1042776
    ...for " Chinard " thanxs for the website info ..I will make sure to read it ..and for " greencuke " ..how much for the duster ..? what color is it ..? what shape is it in ..? and most important , is the window clear .. or scrathed up and milky white ( like every soft top plastic I have )..?....if it is in good shape and and the color is right I would be interested ..(black or dark gray).. thanx guys [addsig]
  11. #11
    MudderChuck is
    has no status.
    Jul 2002
    1,382
    1042777
    The heater I was talking about is a water heater with a thick metal case. Requires running extra heater hoses. The twelve volt electric heaters I´ve seen, don´t work well, don´t really put out much heat. But can help defrost the windows a little in the first few minutes of driving, if pointed directly at the windshield. A polishing compound for clear coat paint, works well in cleaning up the plastic windows and a coat of wax will help keep them clean. They make heaters, that work with a burn chamber, a fuel pump and an electric blower that put out a bunch of heat, they are a little pricey. A second water heater and maybe the blower from a blazer should keep you toasty. My YJ will most times sweat me out of the soft top, if everything is turned up full. Don´t forget to check and see if the flaps in your heater and vent are properly adjusted and opening all the way and closing the outside air completly. Looking inside of your radiator (at the cap)will give you a tip on what the inside of your heater core looks like, might be time for a flush. [img]modules/phpBB_14/images/smiles/icon_wink.gif[/img] [addsig]
    DO IT IN THE MUD!
  12. #12
    Greencuke's Avatar
    Greencuke is
    has no status.
    Sep 2002
    bagdad
    412
    1042799
    its leather black, in great shape, it came w/ my jeep when i bought it and as far as i can tell they never even used it, if u want it, its urs [addsig]
  13. #13
    Greencuke's Avatar
    Greencuke is
    has no status.
    Sep 2002
    bagdad
    412
    1042888
    yeah, i dunno about that...[addsig]
  14. #14
    hi_c's Avatar
    hi_c is offline Senior Member
    hi_c is
    has no status.
    Jul 2002
    Charleston, SC
    734
    1042961
    they sell these really cool heaters at lots of popular stores (ie WalMart, K-mart, etc.) and they're real cheap. They come in different shapes and fit in a variety of ways. They are called 'coats' sometimes 'jackets' and for your backseat passengers their called 'blankets'. Or you can do what i did and move down south!
    [img]modules/phpBB_14/images/smiles/icon_lol.gif[/img] [img]modules/phpBB_14/images/smiles/icon_razz.gif[/img] [img]modules/phpBB_14/images/smiles/icon_lol.gif[/img] [addsig]
    89 YJ 2.5L, 4\" Hell Creek Susp., .5\" homemade lift shackles, 33x10.50 on TJ Grizzly Alloys, Herculined tub, K&N, Dynomax Super Turbo Muffler, Russell extended stainless brake lines, & a Congo Cage w/ Yakima bars
    http://coreyandhis.jeepz.com
  15. #15
    Greencuke's Avatar
    Greencuke is
    has no status.
    Sep 2002
    bagdad
    412
    1042964
    well, i have a windjammer and a bikini that id like to get rid of as a package, but if u just want the duster, ill take pretty much what i can get for it[addsig]
  16. #16
    Greencuke's Avatar
    Greencuke is
    has no status.
    Sep 2002
    bagdad
    412
    1042965
  17. #17
    Greencuke's Avatar
    Greencuke is
    has no status.
    Sep 2002
    bagdad
    412
    1043006
    the bikini is in fair shape, no rips or anything, but one or two of the clips needed for mounding need to be replaced. the windjammer in in great shape, i dont think it was ever used, so scratches or anything, and the duster is pretty much the same. as for price, does $100 seem fair? id rather help someone on here out than sell it on ebay... let me know[addsig]
  18. #18
    Greencuke's Avatar
    Greencuke is
    has no status.
    Sep 2002
    bagdad
    412
    1043017
    well, i was kinda hoping to get rid of them as a package...yea, it has rails[addsig]
  19. #19
    TerryMason's Avatar
    TerryMason is
    too big to fail
    Dec 1999
    Virginia Beach VA
    5,713
    Type of Jeep
    TJ Wrangler
    1043018
    Hey Greencuke, if it's $100 with shipping, I'll buy the set off you.
    Terry[addsig]
  20. #20
    Greencuke's Avatar
    Greencuke is
    has no status.
    Sep 2002
    bagdad
    412
    1043020
    whats shipping cost? ive never sold anything online before... but that sounds ok[addsig]
