Old 07-17-2004, 12:11 AM
Send a message via AIM to laneiac
I need to secure the TJ side marker signals in mine and my gals YJs. It has a smooth shaft that goes through the hole in the flare and two "hooks" that secure the upper portion of the light in the flare. Any ideas will be greatly appreciated.
View Public Profile Send a private message to %1$s Show laneiac gallery
Old 07-17-2004, 12:18 AM
Send a message via AIM to red89yj
try to find a nut small enough to go around the tip of the shaft. coarse thread would work good because as you tighten it down, it will cut into the plastic and turn it into a screw. i read about that method, but i just use "DAP" contact cement available at home depot.
31\" BFG radial T/A, 94 XJ 4.0L, 93 XJ AW4, TJ Flare Conversion, Sylvania Silverstar Headlights, BLAZER BLOWER upgrade, Duralined Cab, Custom Made Switch Panel In Console, Pioneer DEH8400-MP Stereo
View Public Profile Send a private message to %1$s Show red89yj gallery red89yj
Old 07-17-2004, 03:25 AM
Bounty__Hunter's Avatar
Moderator
You can use JB Weld or any good epoxy on the plastic shaft. Factory TJ's use a nut that cuts into the plastic shaft, I believe.
  #4 (permalink)
Old 07-17-2004, 03:57 AM
Thanks as usual guys, I will go to work on em tomorrow.
These voices in my head are giving me a headache....
  #5 (permalink)
Old 07-19-2004, 07:18 AM
jps4jeep's Avatar
Real Name: Johnny
Send a message via AIM to jps4jeep
Go to autozone or napa and get interior plastic retaining nuts! The guy behind the counter will look at you like your a retard so don't both to ask! You will have to look in the interior parts section, they were used in a lot of GM vehicles in the 80's to secure trim pieces. Thats what I used and works great. I think I got the 1/2 ones, can't recall though, but they are self threading so when you screw them on, they will lock them selves on.
They are black
they are hex shaped and they are thin, like a washer but are pressed to look like half of a nut.
And they are a b#tch to explain!
-Johnny-
View Public Profile Send a private message to %1$s Show jps4jeep gallery
  #6 (permalink)
Old 07-19-2004, 03:24 PM
Send a message via Yahoo to frankiefire702
The parts that are used from the factory are called speed nuts. You can usually get them at your local auto parts store under the help section. Or you could go by your local bodyshop and they could probably hook you up with the right size.
View Public Profile Send a private message to %1$s Show frankiefire702 gallery
  #7 (permalink)
Old 07-21-2004, 08:10 AM
jps4jeep's Avatar
Real Name: Johnny
Thats what I was trying to describe!
yeehaw
-Johnny-
Message Board Statistics
Jeepz.com RSS2 Feed
Powered by vBulletin® Version 3.7.1
LinkBacks Enabled by vBSEO 3.1.0
