Welcome to Jeepz.com.
Results 1 to 6 of 6
    Mxpx182lit's Avatar
    Mxpx182lit is offline Senior Member
    Mxpx182lit is
    has no status.
    Feb 2003
    Colorado
    383
    RE: Sorry to brag......
    The dash gauges on my 99 quit working about a week ago and i cant figure out why. I;ve replaced the fuse twice (even though it wasnt blown and still isnt) and when i took the dash apart all looked well. I cant stand not knowing my speed or how much gas i have. Please help! Thanks in advance, Justin.
    Bounty__Hunter's Avatar
    Bounty__Hunter is
    working on his new WK
    Nov 2002
    Southern Illinois
    12,249
    Type of Jeep
    YJ Wrangler
    RE: another fuel tank question
    Do you get an airbag light?
    Could be a bad BUS connection where the guage cluster plugs into the wiring harness. Many jeeps have a TSB issued that covers this. To fix you have to seperate the connection and bend the wire tabs inside the connector to make better contact. Then pack with dialectic grease and reconnect, securing it together with zip ties.
    Mxpx182lit's Avatar
    Mxpx182lit is
    has no status.
    Feb 2003
    Colorado
    383
    RE: SNOW!
    well i have an airbag light, but thats becasue i have a Grant steering wheel with no airbag and thats been on since the steering wheel swap.
    Snitty's Avatar
    Snitty is offline Senior Member
    Snitty is
    has no status.
    Nov 2002
    Olean, NY
    5,646
    RE: Radiator ?
    well since you have an airbag light on all the time... this could still be the problem... you just wouldn't have any other signs to signify it
    93 YJ 4.0
    Mxpx182lit's Avatar
    Mxpx182lit is
    has no status.
    Feb 2003
    Colorado
    383
    rusty floorbaord
    Well i finally got around to looking at it, and i noticed the ground wire that bolts behind them goes to nothing. Where is it supposed to go? I bent the tabs and they are still not working. Any other suggestions?
    Mxpx182lit's Avatar
    Mxpx182lit is
    has no status.
    Feb 2003
    Colorado
    383
    ok, it turned out to be a blown fuse. I checked the oned behind the glovebox, but i forgot about the ones under the hood.
