This section Sponsored By
Old 03-06-2005, 09:56 PM
GaryMB's Avatar
Jeep :
Year :
Lift :
Tires :
CJ-7
1984
5"
32"
Real Name: Gary
Send a message via AIM to GaryMB
I just installed 3.5" of lift on my jeep, and am trying to remove the pitman arm (power steering) to install a dropped pitman arm. Now how the heck do you get this sucker off? I tried a puller but it just crunched on the end and slipped off.
BAMFCJ7
View Public Profile Send a private message to %1$s Show GaryMB gallery
Old 03-06-2005, 10:04 PM
berettajeep's Avatar
Jeep :
Year :
Lift :
Tires :
Cherokee
1996
5"
33"
Real Name: Dennis
Pitman arm removal
stating the obvious. You removed the nut? Right? :wink:
I know for mine I added a little heat to the pitman arm before removing it
View Public Profile Send a private message to %1$s Show berettajeep gallery
Old 03-06-2005, 10:14 PM
GaryMB's Avatar
Jeep :
Year :
Lift :
Tires :
CJ-7
1984
5"
32"
Real Name: Gary
RE: Pitman arm removal
Yeah, the nut is off, I had to drive to about 4 hardware stores before I found a 1 5/16" socket for it. I tried heating the pitman arm with a torch for about 30 seconds, but had no luck...I was afraid to heat it too much in case it would damage the seals in the steering box.
BAMFCJ7
  #4 (permalink)
Old 03-07-2005, 12:16 AM
Member
Re: RE: safari bikini,duster,deck cover
Are you using a generic puller or a pitman arm puller? Did you soak it with Liquid Wrench and then hit it with a hammer (the vibes help the Liquid Wrench penetrate)
Not sure heat was a good idea... I think heat would swell it and maybe make it tighter.
View Public Profile Send a private message to %1$s Show nakedjeeper gallery
  #5 (permalink)
Old 03-07-2005, 02:59 AM
Snitty's Avatar
if you are going to use a puller.. you NEED a pitman arm puller. it is a specially designed puller
i used a cut-off wheel, worked great
93 YJ 4.0
  #6 (permalink)
Old 03-07-2005, 10:00 AM
jps4jeep's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1994
3"
Q's the only TSL
Real Name: Johnny
Send a message via AIM to jps4jeep
RE: MIX BEER & REDNECK, You get?
Slowly use the pitman arm puller to pull on the arm, as you are doing this, use a 5lb dead blow hammer (BFH can also work) and hit the arm in it. the steering box has a slight taper on it, and it is speced out to be held on there with 160 ft-lbs, so that son of a "B" is on there! this should pop it off! If not, you can use heat, but do not get too crazy with it!
It used to be a jeep Thing,
But all that stuff broke
-Johnny-
View Public Profile Send a private message to %1$s Show jps4jeep gallery
  #7 (permalink)
Old 03-07-2005, 02:34 PM
Bounty__Hunter's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
6"
36"
RE: Will someone PLEASE buy me this??
Pitman arm puller and BFH has always worked good for me. Hosing it down with PB Blaster wouldn't hurt either.
Crank down the puller nice and snug, then hit the pitman arm where it's around the steering shaft, with the BFH hitting down at a 45º angle. Tighten, hit, repeat. It'll pop off.
If all else fails, cut with an angle grinder into the pitman arm where it's around the steering shaft, parallel with the shaft. Make a cut very close to the steering shaft, then you can pop the arm off by placing a chisel in the cut and hitting it.
  #8 (permalink)
Old 03-07-2005, 03:22 PM
Snitty's Avatar
It works well... I have pics of my mangled pitman somewhere
93 YJ 4.0
  #9 (permalink)
Old 03-07-2005, 03:39 PM
pitman arm puller sold at Autozone $12.00 or you can borrow one from them for free with a deposit
-D-
View Public Profile Send a private message to %1$s Show DerekC gallery
  #10 (permalink)
Old 03-07-2005, 11:06 PM
GaryMB's Avatar
Jeep :
Year :
Lift :
Tires :
CJ-7
1984
5"
32"
Real Name: Gary
I was using a general puller, guess that's why i couldn't get it off. It's been soaking in liquid wrench for a while and my mechanic said he will loan me his pitman arm puller.
BAMFCJ7
  #11 (permalink)
Old 03-07-2005, 11:13 PM
Sully's Avatar
Send a message via AIM to Sully
RE: Re: RE: Help i might be losing my jeep..
Quote:
That's exactly what I do when I have to take mine off. Great minds think a like. :wink:
Sully
PS - Plus lots of PB blaster!
View Public Profile Send a private message to %1$s Show Sully gallery Sully
  #12 (permalink)
Old 03-07-2005, 11:33 PM
Member
RE: Revolver Shackles
I had to use a pitman arm puller,PB blaster,BFH and heat to get mine off.GOOD LUCK!
View Public Profile Send a private message to %1$s Show BigDaddys88YJ gallery
  #13 (permalink)
Old 03-07-2005, 11:40 PM
Send a message via AIM to phatyaspen
can I remove EGR tube? (got new header)
mine come off easy.. soaked her in pb threw a gun on it and tightened it and then i gave up the wifey p'd me off one good hit with a bfh and all i heard was... PING! and wow that works lol
super 30 kit w/ arb 5 on 5.5 hub conversion w/ lock outs, TBT hy steer,Currie 60 w/35 spline Detroit w/disc break conversion,Optima red top,Full inatke, Borla exhaust,Jet Chip,AtoZ Stinger, DH fabrication Rear Bumper, Re 4.5" kit w/ 2" spacers
View Public Profile Send a private message to %1$s Show phatyaspen gallery phatyaspen
  #14 (permalink)
Old 03-07-2005, 11:57 PM
Member
PING! Was that the wife or the pitman arm? lol Just Kidding
  #15 (permalink)
Old 03-09-2005, 02:32 AM
Snitty's Avatar
HAHA. yeah.. so did you ever get the pitman off or what?
93 YJ 4.0
 Subscribe to our RSS feed
