Some simple math is all it takes to figure it out....and its free and will keep you from seeing red and blue while cruising down the highway not knowing really how fast you are going.
Some gear formuals
Gear Ratio
(RPM x Tire Diameter)/(Diff ratio x Trans Ratio x Transf Case Ratio x 336) = MPH
Crawl Ratio
Trans Ratio x Transf Case Ratio x Axle Rato =
Crawl Ratio
New gear ratio
(new tire diameter/old tire diameter) x Old axle ratio = new axle ratio
Speedometer
(new tire diameter/ old tire diameter) * speedometer MPH = Actual MPH
Hope that helps (some of these were borrowed from 4lo.com)
for your deal you will probably need the first one since you changed more stuff than just your tires. Say you are going down the road (your in 2 HI which is 1:1) and your rpm is 3000 and you are 4th (manual) (thats a 1:1 ratio btw) (if you have a auto put it in D (not overdrive)) and this is what you do
Gear Ratio
(3000 x 33)/(4.11 x 1 x 1 x 336) = 71.689 or about 72mph
at 2500 you are going about 60mph
at 2000 about 48mph
try different rpms and then go out and test it
if you want to do lower speeds just adjust the trans ratio for that gear (you will need to find out what your trans gear ratios are for each gear) anything over 40 you will probably be in 4th or final for auto anyway.
its tricky but you can kind of figure out the different speeds at different rpms and then you will know about how off your speedo is. Take note that it will not be the same for all speeds, the faster you go the more off it is. For me I put 31's and kept the same gear ratio in my diffs. I use the last formula to find my speedo fix. My old tires were 28 inch.
Speedometer
at 60mph...
(31/2
X 60 = ~66 mph
at 70 I am really going about 78 mph
at 100 (like my jeep can go that fast with a 4 banger) Im going about 110
but at low speeds like 30 Im only going like 33
with 33's you will be quite a bit more off (10mph over at 60) with your stock diffs just to give you an idea.
Hope that helps... Math is fun
[img]modules/phpBB_14/images/smiles/icon_lol.gif[/img] [img]modules/phpBB_14/images/smiles/icon_lol.gif[/img] [img]modules/phpBB_14/images/smiles/icon_lol.gif[/img] [addsig]
