RE: 33" tires and need a matching rim
redrooster-- I know D60 outers don't grow on trees, but could you just swap to GM knuckles and run all GM from knuckle out?
The spring perches on a Dodge front axle are a little closer than those on a GM or Ford, so if your already setup for one of those, the Dodge axle will pull the springs in a little. It's no big deal though.
West-- isn't your D44 a high pinion? Are you sure you want to swap that out just for 39s in the mud?
