Old 03-16-2005, 12:12 AM
Send a message via AIM to SenorCole86
RE: Local Soldiers Heartwarming Tribute
The other night, I was looking around on the web and came across a site which listed all the ratios in every AMC 20 ever made and the corresponding stamp letters. My stamp read "Y" and I'm pretty sure it isnt worn down or anything. This letter was not listed on the shart and I'm dying to know. Any help would be appreciated, thanks guys.
1980 CJ-7 Renegade
Motorcraft 2150 Carb / GM HEI Ignition / 4.0 HO Head / Clifford Cam+Valve Train / Painless Wiring Harness / Bedlined Interior / 31" TRXUS M/T's / 1.25" Spidertrax Spacers/ and some indeterminate amount of suspension lift
I'm an auto mechanic who works on a doesn't need to know basis.
View Public Profile Send a private message to %1$s Show SenorCole86 gallery
Old 03-16-2005, 08:55 AM
redrooster's Avatar
I don't know about the chart or id numbers, but you should be able to pull the cover and verify the ratio either by looking for the tooth count stamped on the ring gear or by counting the ring gear teeth and dividing by the pinion gear teeth. The ring gear should be stamped on the circumference with several numbers. Two of those will be the tooth count for your gearset. Divide the higher by the lower. I'm going to guess that you have a 3.54 ratio.
1622 Miles from Moab.
View Public Profile Send a private message to %1$s Show redrooster gallery
Old 03-16-2005, 10:08 AM
RE: oil pressure
Alright, thanks.
1980 CJ-7 Renegade
  #4 (permalink)
Old 03-16-2005, 06:20 PM
Sully's Avatar
Moderator
Send a message via AIM to Sully
RE: Check out this ebay auction
Are you sure it's a Y?
Check your front axle gear ratio. The rear will be the same.
View Public Profile Send a private message to %1$s Show Sully gallery Sully
  #5 (permalink)
Old 03-17-2005, 09:16 AM
joeycj5's Avatar
Member
Oh, happy day!!!
Your right, there is no "y" listed.
http://www.jeeptech.com/axle/amc20.html
View Public Profile Send a private message to %1$s Show joeycj5 gallery
Forum Jump
Message Board Statistics
 Subscribe in a reader
