This section
Sponsored By
03-21-2005, 12:33 AM
Jeep :
Year :
Lift :
Tires :
Real Name: Gary
Well the front fenders on my cj are pretty banged up, and I can either try to hammer them out, leave them alone, or cut them to make them flat. ?
BAMFCJ7
03-21-2005, 08:26 AM
go with the flat. i did it to my cj and it looks great.
03-21-2005, 03:05 PM
VT Hokie
Jeep :
Year :
Lift :
Tires :
Real Name: Sam
cut it
94 YJ (daily driver)
06 VW (hardcore crawler)
03-21-2005, 05:44 PM
Real Name: Harry
RE: fast back roll bar and stuff
Flat!
03-21-2005, 06:10 PM
Jeep :
Year :
Lift :
Tires :
Real Name: Matt Pyle
cut 'em flat!
03-21-2005, 08:58 PM
I vote flat.................with pics, of course
03-21-2005, 09:02 PM
unanimous
93 YJ 4.0
03-21-2005, 10:16 PM
RE: DeLorean Dead
Now I'm kinda curious. My fenders are pretty banged up as well. How would one go about cutting then without leaving this ugly metal edge sticking out, weld a tube under it?
1980 CJ-7 Renegade
Motorcraft 2150 Carb / GM HEI Ignition / 4.0 HO Head / Clifford Cam+Valve Train / Painless Wiring Harness / Bedlined Interior / 31" TRXUS M/T's / 1.25" Spidertrax Spacers/ and some indeterminate amount of suspension lift
I'm an auto mechanic who works on a doesn't need to know basis.
03-21-2005, 11:47 PM
VT Hokie
Jeep :
Year :
Lift :
Tires :
Real Name: Sam
RE: Will this body tub swap work?
no, the best way to do it i found is to come up from where thay attatch to the grille, and come out with some sort of arc that works into the front of the fender and then follow it around the side. yj flares will allow you to go partially flat (i like them the best) and tj flares will go paper flat. i dont kno about cj flares though.
03-22-2005, 01:22 AM
Jeep :
Year :
Lift :
Tires :
RE: Check for MUD!!!
Here is what I am thinking of doing...I did this in Paint so don't laugh,,,but it does give a good look at it...a before and after...taking it just at the top of the turn sig..leaving about 1" thickness on the flare. Sorry but I kept the pics large for more detail
before:
After:
IT WAS... a 97 TJ, 7.75" of lift w/disconnects, SYE, 4.88's, 36x14.50 Super Swamper TSL Radials, 4000# Warn Winch NOW...2000 Chevy Z71!
03-22-2005, 06:01 AM
Banned
RE: Flat fender kit for a YJ???
I like that, Terry!
| Sparky-Watts's Arcade Awards |
03-22-2005, 08:00 AM
That looks pretty good. Cut em off.
03-22-2005, 09:49 AM
fenders are like those little extra tab pieces you find on old plastic toys. For example, army men, often you'd find extra flaps of plastic hanging from Sgt. Sloppy Joe's arm. Or Private Thumblethumb would have webbed legs. You're just supposed to realize that they were accidently left there, and just pull them off
93 YJ 4.0
03-22-2005, 08:59 PM
What do you do with your turn signals?
YJ 94 2.5L, K&N. 1\' BL. 31\" ProComp Xterain
Have fun in life...get a Jeep!!!!!
03-22-2005, 09:30 PM
Moderator
Put one mark down for the CJ.
CJ's have signals on the grill. TJ's dont.  Move the signals onto the grill.
03-22-2005, 09:46 PM
VT Hokie
Jeep :
Year :
Lift :
Tires :
Real Name: Sam
get some cj turn signals and mount them on the grill, or look in jp, they had a pretty good idea also. they used the flush mount kind that use a rubber gasket to hold them in place, the same style lots of people use for flush mount tail lights
03-22-2005, 11:05 PM
RE: How do I remove factory decals?
The turn signals on my CJ are covered up by my winch, so i have some that mount to the side of the winch bumper. If you ever plan on getting a winch in the future, you could probably avoid this by mounting the new blinkers up pretty high.
1980 CJ-7 Renegade
03-23-2005, 06:02 AM
Banned
Intake & Manifold Woes
YJ, too!
03-23-2005, 09:13 PM
cut em! get some aftermarket flush mounts for the grille (LED) and run with it!
Bob in Vegas
89 YJ-4.2/5spd,Herculiner tub,4"HellCreek Lift,Cable front axle,Flush LED tailights,Hella,KC,33x12.5 BFG M/T on Eagle Alloys,flatfender,55w backup lights, Steves Jeep Rear bumper,Bestop extendatrunk w/top mounted spare,Cobra CB w/rear dual antenna, misc. trail rash
| Thread Tools |
| Display Modes |
Linear Mode
