1044511
The soft uppers are unfortunately not going to fit flush against the hardtop... I have seen the occasional jeep with a hardtop and soft upper doors, and while it appears that you can get the doors to close, the soft uppers are much wider than the upper half of full steel doors and dont really seal as a result.
If you're looking to save some cash... You could try to locate a set of those aftermarket hard upper doors that slide open. They would probably be cheaper than full doors.
good luck,
jim
85 CJ[addsig]
85 CJ7:BBD:258:T5  300:AMC 20 w/1-piece shafts:2\" AALs:31s
