RE: Re: RE: Re: RE: This woman is taking resourcefullness a
If you have a completely factory set up, remove the restrictor inside the box it-self (million writeups on the web) then replace the coregated portion of the tubing and replace it with a smooth piece of Schedual 40 PVC tubing. (same OD diameter ase the box) this will give you the same effect as a cold air intake.
