You have a lot of options depending on money, time and how big you want to go. It will be expensive to swap t-cases, but worth it. If you don't want to swap then you could find some Wagoneer D44's with the rear offset and the correct front. This will get you wider and strong enough to run 36's.
If you want to swap cases then you should try either a GM case like the NP205 (large case with 2.0 ratio) or the Dana 300 (small case with 2.62??? ratio). Then you will be able to get a more common centered rear and passenger side front axle (8.8 rear and a 44 front).
The 205 Case can be adapted by acquiring a used or new GM factory adapter and output shaft for your transmission. The Jeep and GM 400's are the same internally, so shafts and matching adapters can be swapped.
The best swap would be to the Dana 300. It is small, strong and will fit nicely. It also has a good ratio. The adapter kit is around $410 from Novak and includes seals, output shaft and aluminum adapter,
The transmission will have to be disassembled for the output shaft swap with either case. Driveshaft mods will have to be made also (you will need them with an SOA anyway).
I have a 78 CJ7 with the AMC 360 TH400, Novak adapter and an Atlas II case (same pattern and shaft as the Dana 300 uses). PM me if you have any questions.
1622 Miles from Moab.
