05-15-2005, 10:08 PM
Cool product for coil sprung front ends
Ordering my lift tonight, trying to figure out how big of tires i should go with little to no hassle.
05-15-2005, 10:14 PM
Good rim/tire size for a TJ w/ 4" Skyjacker lift?
Gears? Axles? 4banger, 6banger?
05-15-2005, 10:20 PM
RE: Cool product for coil sprung front ends
I'd go with 33x12.50's on 15x8" wheels.
But yes, axles, gears, engine, and all that stuff make a difference.
05-15-2005, 10:30 PM
Real Name: Harry
Re: RE: More evidence, that I have too much time on my hands
285/75 QR16 BFG Muds on 16x8 Wheels
thats a true 33" tire(actualy 33.1) with an 11" center section. Most 33x12.50's are between 32.5"-32.8"
05-15-2005, 10:37 PM
RE: Re: RE: Re: RE: Re: RE: Re: RE: 15x7 Jeep wheels
Not sure on gears/axles/etc...its a stock 2005 Wrangler X Special Edition with a 4.0L/Automatic Tranny.
Trying to order this kit tonight, theres so many options tho...Do these kits include all i'll need?
http://www.4wheelonline.com/Products...ProductId=3900
http://www.4wheelsupply.com/cat.cgi?s="wrangler+tj"+"TJ401KSTN"&c=SL
TJ401KSTN
"4"" Standard System Lift Kit w/ Nitro Shocks (Soft Top)"
The second link is a better deal, i think they are the same thing. The year doesnt say 2005 but im pretty sure it will be fine.
05-16-2005, 08:53 AM
Just went with the 2nd link and bought it. My question really was is 33" the biggest tire i can squeeze now? I dont want any rubbing, etc.
05-16-2005, 10:34 AM
Real Name: Johnny
Re: RE: 2wd vs. 4wd Disc Brakes
The answer to that question goes either way!
Yes, a TJ with 4" of lift can fit a 35" tire...But... It will rub like a SOB! also your D35 rear is not up to the task of handling 35" tires for long if you plan to wheel! heck, 33" tires will be fine on a D35 rear assuming you do not lock it! Once you install a locker, you put a lot more stress on the axle splines when in a situation where the rotational torque applied to those splines is increased cause instead of transfering power to a wheel with less traction, both axles will receive it equally.
also you probably have either 3.07's or 3.54's You can drive with both and 33" tires, but 35" are a stretch for 3.07's I have 3.07's and 33" tires on my YJ for the past 5 years, you'll adapt you driving style.
-Johnny-
05-16-2005, 10:46 AM
33"s it is....i ordered nitro shocks, now i regret it after reading a FAQ. They dont do well with normal driving?
05-16-2005, 11:49 AM
broken tap
I have the Skyjacker 4" lift. I can't remember what the part number was, but mine came with everything except the brake light relocation kit. That wasn't a big deal since I did it myself with set of fat washers. My 33x12.5x15"s don't even come close to rubbing unless I'm super flexed. However, they do rub on the front lower control arms if I'm flexed and turning at the same time. That's no big deal as far as I'm concerned. I also have the nitro shocks on mine and when I put the hard top on I almost got seasick when I drove it the first time. That problem shall be fixed as soon as I get my Ranchos since one of my rear shocks is now bent just a smidge from an unfortunate encounter with a boulder.
Good Luck!
BOHICA!
05-16-2005, 12:21 PM
Do I need the computer in my 87 YJ?
Thanks for the replies guys, called the guy who runs this site hes going to have to modify the kit to make it work on 05' and switched me back to hydros.
05-16-2005, 12:51 PM
I'd not even get the shocks and order a set of Ranchos. saves you from having to take it apart again in the future.
BOHICA!
05-16-2005, 01:22 PM
Moderator
Real Name: Chris
You should be happy with the Hydros. They aren't the best shocks on the market, but I feel they are as good or better than most in their price range. The Hydros are soft enough for comfort, but firm enough to control big tires.
05-16-2005, 02:09 PM
Ya im not a serious off-roader type. I just like to get a little dirty on the weekends.
| Thread Tools |
| Display Modes |
Linear Mode
