Old 05-19-2005, 11:56 AM
I just cranked my freshly rebuilt motor over this weekend. Noticed it was not firing correclty so I checked my spark on each plug and found all the firing was on the no 3 spark. Popped out my distributor to find the gears ground away. I called the cam shop and the machine shop that assembled the short block. The thought is because I used a high flow oil pump this could be creating the problem. Have any of you ever heard this?
View Public Profile Send a private message to %1$s Show pushead gallery
Old 05-20-2005, 11:37 AM
Oil starvation. You'll have to check your main gallery, it may be blocked somewhere. Best thing to do is get an oil pressure tank somewhere and connect it where the pump hooks up. W/O the pan on see if you get flow. You should see oil dripping down at all of the jurnals.
Sorry have to run..........
Ritt
My Jeep Pics
48 Willys CJ2A
- running wet, loud, and stinky.
93 YJ - 4.0, 4.11, Detroit TureTrac, BFG 33 M/Ts, 6 in lift..............and a bottle opener for fun
View Public Profile Send a private message to %1$s Show Ritt gallery
Old 05-20-2005, 05:06 PM
Re: RE: Re: RE: Re: RE: First JEEP stitches!!!
Called Clifford performance and a few other cam and machine shops today. Didnt even mention my hi flow oil pump just said my dist gear and cam gear where ate alive. First thing they all said was I ran a hi flow oil pump. A big no, no. Clifford has tested this and found the gears can be destroyed in as little as 6 seconds after inital start up.
  #4 (permalink)
Old 05-21-2005, 11:22 AM
Real Name: Chris
That sucks.
Is there any other related engine damage?
View Public Profile Send a private message to %1$s Show Junkpile gallery
  #5 (permalink)
Old 05-21-2005, 05:31 PM
RE: Re: RE: 1979 CJ 7
Hope not. I was told to replace the valves, cam and oil pump and go from there.
Forum Jump
Message Board Statistics
 Subscribe in a reader
