Wagoneer Dana 44 bolt pattern?
Let me quess... Dave in Ashby?
Thats where I got mine..the bolt pattern is 6 on 5.5, same as a chevy, toyota, Nissan, Issuzu and most all FSJ
Those axles will not bolt into a Yj though.. takes a little work, you will have to weld and odify the front drivers side perch, you will need to cut and grind the diff housing slightly to move the center pin over like 1/2 inch. food thing is, if you are lifted, the front trac bar mount (need to be moved) but is re-usable, it is about 3 inches taller than factory YJ.. If unlifted, you will need to cut down and weld to the housing.
You may or may not have the Vacumn disconnect (not the most desirable) but can be done... Both bounty and i have that axle, unfortunatly I have not tore in the front, I am almost done with building the rear. I doubt you will have manual hubs... those were on the earlier FSJ's and they were pass. side diffs.
Good luck, if you got questions, ask away!
-Johnny-
