Welcome to Jeepz.com.
Results 1 to 10 of 10
    buddie22's Avatar
    buddie22 is offline Junior Member
    buddie22 is
    has no status.
    Jul 2005
    16
    YJ no stock source
    I have a 90 yj i have had an idle problem about 6 months ago and and one day it just went away .So the last couple of months i have been upgrading things like brakes tires ect and well last week much to my horror the problem reapeared.Originaly when i had the problemi had found a crack in the intake and got that fixed and it did nothing.any way i have replace the cap, rotor ,wires,plugs and checked every vacumn line and even bypassed the computer.I know the carb is good cause i tried my carb on a buddies jeep and his on mine and nothing changed on mine or his.the engine is a fairly fresh rebuild (2500 miles) good o2 sensor and EGR vale any one have any ideas .any suggestions are greatly appreciated.I have a 67 comaro with a fresh 350 in at at my buddies place but havent had time to play with it cuz my fav wheels ain runnin good and well like every one else i gotta work to
    PLEASE HELP A TIRED JEEP connisuer (if thats the right spelling)
    By the way i am usualy fairly knowledgable about the jeep engines and electrical and have any diagrams u might need so give me a holler
    bud11@eastlink.ca
    TwistedCopper's Avatar
    TwistedCopper is offline Senior Member
    TwistedCopper is
    living the dream
    Jun 2003
    Pennsylvania
    8,942
    Type of Jeep
    YJ Wrangler
    RE: YJ no stock source
    Could be a bad fuel pump? Lines? Tank? Clogged catalytic converter?
    Have you ruled any of that out?
    GaryMB's Avatar
    GaryMB is offline Senior Member
    GaryMB is
    has no status.
    Oct 2004
    CA
    632
    Type of Jeep
    CJ-7
    RE: HOLY $@#$ dont know what else to try
    Perhaps a bad coil or alternator or battery, possibly a bad gasket or there is something screwy with the voltage at the choke wire?
    BAMFCJ7
    Snitty's Avatar
    Snitty is offline Senior Member
    Snitty is
    has no status.
    Nov 2002
    Olean, NY
    5,646
    RE: Building a stroker out of a 4.0L
    I thought coil as well. summer can be bad on them because it can seperate the windings and cause failure
    93 YJ 4.0
    buddie22's Avatar
    buddie22 is
    has no status.
    Jul 2005
    16
    thanks guys all tried and checked still no go
    Robrt-Stephens's Avatar
    Robrt-Stephens is offline Senior Member
    Robrt-Stephens is
    has no status.
    Mar 2005
    Whitefish Montana
    103
    is the carb bolted tight to the base plate at the maifold seal (air leak)?
    Fresh gas tank?
    Add some alcohol and one teaspoon of white cane sugar into the gas tank.
    Also, a hidden vacuum leak will cause this and if it is small the sugar will seal it, generally.
    Let us all know.
    Robert
    Robert A.M. Stephens, LLC,
    NASA-Smithsonian-Documentation Program
    40 years of Jeeps.....and countin\'......
    http://behold-the-rage.com
  7. #7
    Sparky-Watts's Avatar
    Sparky-Watts is offline Banned
    Sparky-Watts is
    has no status.
    Feb 2004
    I'm here just for TwistedCopper!
    5,098
    Quote Originally Posted by Robrt-Stephens
    Fresh gas tank?
    Let us all know.
    Robert
    Interesting! That's the first time I've heard that sugar added to the gas tank can actually be beneficial! Small amounts, of course, not like the 5lb bags we used in our more destructive younger years..... :wink:
  8. #8
    buddie22's Avatar
    buddie22 is
    has no status.
    Jul 2005
    16
    thanks the sugar thing does make sense you are talking about the carbon from the sugar possibly sealing a small leak in the manifold correct ?
    a 5lb bag tho all i have is a 7lb bag will that do (kidding of course )but i will try a teaspoon for sure definitley makes sense .Just curious where did this idea come from i though i knew laot of tricks like pepper to seal a coolant leak but sugar wow .
    Thanks
    BOB
  9. #9
    buddie22's Avatar
    buddie22 is
    has no status.
    Jul 2005
    16
    hmm i wonder if for an automatic tranny if the fluid starts to get black maybe ketchup byight bring back the red color J/k
  10. #10
    Sparky-Watts is
    has no status.
    Feb 2004
    5,098
    RE: Sporatic vibration
    Pepper for a coolant leak? Never heard of that one. I've used a raw egg before to seal a hole in a radiator till I could get back to a shop.
