Old 07-27-2005, 02:11 AM
hoobness's Avatar
I like the portability, F & R accesibility, and non-permanent mounting of receiver mounted winches.
IM not sure about the strength of the attachment though- being the winch is only attached to the vehicle as strong as the reciever is attached to the jeep... Is that something I should even consider?
Also is it sometimes more of a pain in the arse to use it if you are stuck deep in mud or at weird angles... ??
Looking to buy a winch, and how I want to mount it is important...
View Public Profile Send a private message to %1$s Show hoobness gallery hoobness
Old 07-27-2005, 06:40 AM
Real Name: Joe Irvine
Send a message via ICQ to graewulf Send a message via AIM to graewulf Send a message via MSN to graewulf Send a message via Yahoo to graewulf
RE: 87 Cherokee won
Keep in mind most receivers are rated for at least 5000lb (front are 9000lb) line pull in a straight line. At least as much as a bumper mount. The only real drawback that I see is that the winch will stick out further and be lower - easier to hang up on. I know.. you can say "I'll carry it in back till I need it" but try to install it in a mud pit... not a good idea, so you'll leave it in the front receiver. Winches are always harder to use at an angle. Thats why you should carry straps/cables to extend the winch line straight out if you are stuck.
When I Die, Bury me in my JEEP. 'Cause it's never been in a hole it couldn't get out of!
View Public Profile Send a private message to %1$s Show graewulf gallery graewulf
Old 07-27-2005, 10:16 AM
hoobness's Avatar
RE: YJ STUFF
if i were stuck head in or in such a way that a front mounted winch is no use, can a set of pulleys and or trees hep me out?
  #4 (permalink)
Old 07-27-2005, 10:46 AM
Bounty__Hunter's Avatar
Moderator
Have you ever picked up a winch? Do it once and you won't want to be lugging that thing around.
Receiver mounts are very poor for anything but a dead straight-on pull, any amount of side-pull puts a ton of sideways leverage on the receiver, something they're not really designed for.
The need for a winch in the back is a lot less than you would think. Not to mention the major decrease in approach and departure angles when the winch is in place.
  #5 (permalink)
Old 07-27-2005, 02:56 PM
RE: AMC V-8 Dist Drive Gear
Quote:
That's why you have a friend and a snatch strap.....
  #6 (permalink)
Old 07-27-2005, 07:21 PM
TwistedCopper's Avatar
Real Name: Harry
I agree. Front mount atop (or inside) the bumper all the way and don't think twice about it. It's not worth the loss of ground clearance for the possibility there may be a use for it in the rear.
I'm pretty confident my front receiver is stronger than any tow hook (being mounted on both sides of the frame with 6 bolts), but pretty much all recovery points are meant for pulling straight on. I guess the effectiveness of a receiver depends greatly on how it is mounted.
Forum Jump
Message Board Statistics
 Subscribe in a reader
